Auxiliary gas tank?
Old Apr 5, 2021 | 09:11 AM
guidowitz's Avatar
guidowitz
Trailering
Auxiliary gas tank?
I have a 2015 F-350 power stroke super cab
with a short bed.
Is there an option for an auxiliary fuel tank
that mounts like the stock tank? I use it as a truck camper so cannot be in the bed. Must be located like the stock tank which is less than 35 gal I believe?
Old Apr 5, 2021 | 09:28 AM
Desert Don's Avatar
Desert Don
with a short bed.
Check Titan or S&B. Both make over sized replacement tanks.
Old Apr 5, 2021 | 09:32 AM
guidowitz's Avatar
guidowitz
Trailering
Quite right, but those tanks are for crew cabs and mine is a “super cab”
Old Apr 5, 2021 | 09:37 AM
Desert Don's Avatar
Desert Don
Well, I guess Google will have to do for you then, because that is all I know about.
Old Apr 5, 2021 | 09:52 AM
guidowitz's Avatar
guidowitz
Trailering
My only option may be to use the auxiliary fuel tank by Titan that locates in the spare tire area and then mount my spare in front.
That would cost approximately $3500 but may be my only option. Wishing I had. crew cab now!
Old Apr 5, 2021 | 11:08 AM
Overkill2's Avatar
Overkill2
I doubt Ford makes a different tank for the Super cabs as opposed to the crew cabs. But I could be wrong.
If your tank capacity is 26 gallons like mine, check it out, then the S&B tank will work. Or give them or Titan a call to find out. I prefer S&B.
Old Apr 5, 2021 | 11:14 AM
Overkill2's Avatar
Overkill2
Okay from here:
https://www.oemford.parts/v-2015-for...--fuel-storage
It's up to you to dig into this further to see if this includes your Super Cab in these 3 different wheelbases. Have at it. Do your own research unless someone knows. Or call S&B.
Old Apr 5, 2021 | 11:23 AM
guidowitz's Avatar
guidowitz
Trailering
I believe the crew cabs could come with larger tanks as an option but that our super cabs cannot. Probably based on shorter wheel base?
This is still true for 2021 models according
to the Ford dealer I was working with when trying to order specs for a 2021 model.
Old Apr 5, 2021 | 11:37 AM
Overkill2's Avatar
Overkill2
I'd call S&B or Titan and see what they say. Measure your wheelbase and then you'll know what you're dealing with.
Old Apr 5, 2021 | 11:38 AM
guidowitz's Avatar
guidowitz
Trailering
Thanks that is what I shall do!
Old Apr 5, 2021 | 11:45 AM
Overkill2's Avatar
Overkill2
https://media.ford.com/content/dam/f...Duty_Specs.pdf
Merry Christmas! Early but...
Old Apr 5, 2021 | 02:18 PM
guidowitz's Avatar
guidowitz
Trailering
Hey thanks for that info.....26 gal huge mistake!
Old Apr 5, 2021 | 03:39 PM
ssunit1's Avatar
ssunit1
Think my 2015 F250 had a 24 gal tank. Which was a joke. That’s why I got the aux tank.
Nice to know Ford saw the error of their ways and upgraded to a 26 gal.
Old Apr 5, 2021 | 04:47 PM
Overkill2's Avatar
Overkill2
Yeah buddy!!!
Old Apr 5, 2021 | 04:58 PM
Just Strokin's Avatar
Just Strokin
Is your truck gas or diesel? I think the aft gas tank is for gas.
