Brakes
Old Mar 31, 2021 | 11:40 AM
ragwin's Avatar
ragwin
Brakes
Factory or aftermarket? Pros and cons.
Old Mar 31, 2021 | 12:15 PM
Pugga's Avatar
Pugga
When the time comes, I'm going aftermarket. The OEM ones produce way too much dust for my liking.
Old Mar 31, 2021 | 05:08 PM
dirthawg's Avatar
dirthawg
I always go OEM because here is how I see it.
OEM stops just fine but does make a dusty mess I can live with that. Aftermarket you either go ceramic for no dust and have less stopping ability or you go metalic which reduces dust but eats rotors because the pads are so hard.
Old Mar 31, 2021 | 05:20 PM
Overkill2's Avatar
Overkill2
For my 16 which I had corrosion on the front rotors which took out chunks of the rotors, I went with a set of these for replacement:
https://www.rockauto.com/en/moreinfo...ZuCemlZAKkpE3B
The rears weren't bad but had some start of corrosion on the rotors, so my buddy who works on my truck, put the rears on as well. I have to check on the time of replacement and miles on truck.
Powerstop CRK6405. So far so good. I don't know if the link will work or not.
Old Mar 31, 2021 | 05:45 PM
senix's Avatar
senix
for my 2013 I put frozen rotors with slots and hawk heavy duty pads. They were excellent.
Old Mar 31, 2021 | 09:30 PM
lynnmor's Avatar
lynnmor
I'll use the same when replacement time comes, the factory parts have no rust resistant treatment whatsoever.
Old Apr 1, 2021 | 07:32 PM
Overkill2's Avatar
Overkill2
They were put on at 42720 miles in June 2019. I have just over 72k miles now. I'm gonna wait for warmer weather to lube my front wheel bearings with my Riff Raff tool, so I'll be able to get a better look at the brakes when I do. I've been meaning to do it sooner but it never happened.
Here's the pics of the fronts:
This side wasn't bad...
the rears had a small spot or two. I wish my buddy would have left them on but put on the new pads and rotors on the rears since I had them.
Old Apr 1, 2021 | 07:51 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I love EBC pads!
Old Apr 2, 2021 | 07:34 AM
lynnmor's Avatar
lynnmor
That really appears to be a bad casting in the first place, For salt to move up into a layer below the surface, my thought is that the casting was contaminated and layered. Salt is the devil but there is more going on with that rotor.
Old Apr 2, 2021 | 10:03 AM
Overkill2's Avatar
Overkill2
Thanks for your thoughts... original from the factory.
Old Apr 10, 2021 | 03:13 PM
speakerfritz's Avatar
speakerfritz
Got 85k out of my previous stock pads and rotors
2track
2015 - 2020 F150
15
Jul 15, 2021 10:52 AM
Buck268
2009 - 2014 F150
Sep 24, 2014 03:50 PM
jg6250
Sep 3, 2010 06:26 PM
chazman
Jan 21, 2008 04:14 PM
duallyman
Aug 11, 2003 09:56 AM
