No electric from battery
Old Mar 14, 2021 | 08:33 AM
wenchwithwrench's Avatar
wenchwithwrench
4wd Low
Red face No electric from battery
1997 Ford F250 with 7.5 pickup My truck's battery drained during the deep freeze a couple weeks back. I charged it and everything was kinda of OK. It wasn't staying charged. I guess one of the battery post clamps was not tight. I tightened it and put my battery charger with starter boost on and attempted to start it.
Now I have charged battery(13.4V) and no power to lights or anything else. Where do I start? I had truck towed home and I don't want to pay to haul it to my mechanic. Thanks
Old Mar 14, 2021 | 09:34 AM
Binkowski's Avatar
Binkowski
The battery is toast. Replace it with a quality battery and you'll be good to go. Everyone has their favorite place to buy a battery...I like WalMart because they are everywhere and there's no hassle returns and exchanges if there's an issue.
Old Mar 14, 2021 | 10:47 AM
wenchwithwrench
4wd Low
I thought I would take it to Autozone today and have them test it. It is a NAPA battery, about 3 years old. Thanks
Old Mar 14, 2021 | 02:19 PM
88n94's Avatar
88n94
Do you have power to the lights or anything else when the battery charger is hooked up?
Old Mar 14, 2021 | 02:39 PM
f5fordgirl's Avatar
f5fordgirl
If you have those quick fix cable ends, clean and tighten them first, but as stated, it could be the battery.
Old Mar 14, 2021 | 05:35 PM
wenchwithwrench
4wd Low
Battery tested good. There is no power when battery is installed and on charger. I started taking apart wires. The fusible link at the starter relay is very corroded where it connects to yellow wire going to power block. I'll go back to store tomorrow and pickup 12 gauge fusible links.
I hope that solves it.
Old Mar 14, 2021 | 06:25 PM
Kenneth P's Avatar
Kenneth P
Check your battery cables to make sure they haven't corroded on inside of cable at the connector's
bigtexan99
Jul 25, 2012 08:54 PM
Tony_C
Dec 13, 2011 11:53 AM
MDSuperDuty
Jan 11, 2011 07:50 AM
RyanMiller
Electrical Systems/Wiring
Oct 16, 2004 05:09 PM
jmarsa
Mar 24, 2004 08:36 AM
