Battery Starting Problem
Old Mar 22, 2004 | 08:55 PM
jmarsa's Avatar
jmarsa
Hi, I'm new around here. My 2001 5.4L F-350 has started having a weird starting problem. Basically it goes like this. Dead battery. I get out the charger/starter and jump it with the 200Amp start mode. It takes about 30 secs and it starts right up. Let it run for 60 secs. and shut it off. Crank it again and no problem, drive it around town, goto the store no prob. Fast forward to the next day or two (I don't drive it every day) and same issue all over. The battery is OEM and still has the green eye (proves only one cell is good right?) Lights are off, cargo light is off, everythings off.
I'm not sure if it's the battey or a short? Any ideas?
Thanks in advance,
--JMarsa
Old Mar 22, 2004 | 09:12 PM
Mil1ion's Avatar
Mil1ion
Batteries should receive a full charge from a battery charger instead of thinking that thr alternator will bring it back up.
I suggest to fully charge the battery, then check for where the power drain is coming from.
Old Mar 22, 2004 | 10:55 PM
jmarsa's Avatar
jmarsa
Thanks for the advice. I'll charge it all the way up and go from there. It almost seems like there is a "battery buddy" (not sure if they still make those) like device that is preventing the complete drain of the battery. When I go to start it, it's dead, no lights no click, nothing. 30 secs of a boost and it's like it's "reset" and cranks over with full power repetitively.
--JMarsa
Old Mar 23, 2004 | 02:12 PM
Franklin2's Avatar
Franklin2
"When I go to start it, it's dead, no lights no click, nothing. 30 secs of a boost and it's like it's "reset" and cranks over with full power repetitively"
The first thing I would do(it's cheap) is to take all the heavy battery wire connections off the battery, engine block, and starter relay, and scrape them clean.
If that doesn't fix it, then I would suspect the battery. A totally discharged battery should take a while to charge back up.
Old Mar 23, 2004 | 06:39 PM
4x4lowandslow's Avatar
4x4lowandslow
Check the voltage right at the battery the next time it doesn't crank and see if it really is a battery issue. Keep us posted.
Old Mar 24, 2004 | 08:36 AM
jmarsa's Avatar
jmarsa
I jumped it again last night, and then drove around awhile. When I came home I charged in on the 40 Amp cycle for 1/2 hour. I'll check it when I get home tonight and check the battery voltage.
Thanks for the advice,
--JMarsa
