1966 - 1977 Early Broncos
Power Steering Pump Options
Old Mar 8, 2021 | 06:31 PM
louisvillebroncoboy's Avatar
louisvillebroncoboy
Hoping to get some suggestions on this.
backstory, have a 77 bronco I’m trying to bring back from the dead. Have redone brake lines, tranny, etc and was finally getting to drive it this weekend. It is 351w swapped and running accessory drive from a late 70s car with a CII style pump. I recently replaced the pump with a new one (with resovoir) from Rockauto as the old one I had was leaking around the resovoir o ring and run for a while without fluid unknowingly. Took it around the block and was having a wobble so I took it home and parked it in driveway. Upon determining it needed to go back in the garage I fired it up to drive it in and it hemorrhaged fluid everywhere. Hose was slightly loose so I tightened that and started to refill it when I noticed it was also dripping out the bottom of the housing again as I was filling it. Confirmed it is the housing leaking and not just residual blown out fluid.
so that leaves me with not great options. Can keep trying to fix this pump, but frankly I think the resovoir design is terrible not having positive pressure against the o ring and certainly not robust for wheeling like I intend to do. I have seen Saginaw conversions done and I like those pumps much better but that would require major accessory drive changes.
basically just wanting opinions from those who have done the conversion or suggestions for stuff to look at in terms of fixing the cii. Any advice is appreciated!
Old Mar 22, 2021 | 03:34 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I did not do the conversion on mine (PO already did it the Sag conversion). But it turns my 35X14.50 x15 boggers just fine. I believe you can get a bracket and pump and not have to re-engineer the accessory drive?
Wild Horse has a nice conversion kit to a Sag pump. https://www.wildhorses4x4.com/produc..._Steering_Kits
All HD kits https://www.wildhorses4x4.com/catego...Steering_Pumps
Toms bronco parts has kits. https://www.tomsbroncoparts.com/cate...power-steering
CJ P parts https://www.cjponyparts.com/borgeson...SAAEgL_uvD_BwE
Classic Bronco has some nice tech threads. https://classicbroncos.com/tech/sagi...g-pump-upgrade
And https://classicbroncos.com/tech/sagi...wn-vic-engines
More tech talk. https://www.4x4review.com/buckshot-steering-upgrade/
And https://classicbroncos.com/forums/sh...ad.php?t=43083
And then check out the Stone Crusher steering mod. https://classicbroncos.com/tech/stone-crusher-steering
Duffs kit includes the steering box. https://dufftuff.com/product/power-s...966-77-bronco/
Swap talk. http://www.garysgaragemahal.com/sagi...versions1.html
Pump @BG. https://shop.broncograveyard.com/Sag...uctinfo/20975/
Sexton Off Road. https://sextonoffroad.com/i-14431160...grade-kit.html
Borgeson and get a steering shaft. https://www.borgeson.com/xcart/home.php?cat=86
Old Mar 22, 2021 | 10:19 PM
Boba Fett's Avatar
Boba Fett
Ditto on what he said - the "Canned ham" Saginaw pump is what you need if you re blowing pumps that fast......
Mikec35
15
Apr 12, 2020 04:34 AM
Portagepd86
Dec 20, 2014 08:05 AM
nevrenufhp
Aug 21, 2014 10:56 PM
asavage
Aerostar
26
Feb 8, 2008 04:05 PM
05PowerStroke
Feb 1, 2008 07:36 AM
