Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Clunking noise from rear(pass side), seeking insight
Old Dec 30, 2020 | 07:41 AM
StangNutt's Avatar
StangNutt
Hello All,
I'm new to this forum, but not to Ford Trucks. I'm having a bit of a problem trying to figure out a issue with my 03' HD Ed. Here goes:
From a cold start, when pulling off, you hear a popping, clunking sound from start at low speeds, which I've determined is coming from the rear (pass side) Once the vehicle warms up in travel, the sound goes away, but still vibrates as you apply brakes coming to a stop. This truck should be considered a 2020, for all bushings, tires, bent wheels replaced, tie-rods, rotors, brakes, shocks, & rear wheel bearings have been replace within the last 7mths after purchasing the truck. I've had the transmission and rear-end inspected/service from 2 different shops and both stated, nothing is wrong with either. The only thing I consider that may be the issue is, the shop wasn't able to install the Belltech shocks, so they opt to install 'regular' heavy duty shocks for a F150. (I will replace w/Bilstein when $$ allows me to.) Any suggestion on what may be the problem? Forgive me if this posting is out here. I wasn't able to find it in my search before posting.
Old Dec 30, 2020 | 10:35 AM
alloro's Avatar
alloro
Pull the rotor and inspect the parking brake assembly for broken springs, shoes, or hold-downs.
Old Dec 30, 2020 | 11:05 AM
StangNutt's Avatar
StangNutt
Thanks alloro! I'll check for that as soon as I return back to area., will update then.
Old Dec 31, 2020 | 06:02 AM
2dwoods's Avatar
2dwoods
Look at your springs too ,bushings might be wore out causing some axle wrap when loaded or braking and u bolts tight
Old Jan 12, 2021 | 11:31 AM
StangNutt's Avatar
StangNutt
Update: Thanks for all the input. I was able to get it checked out and it was discovered that there is a leak from when the rear bearings were replaced., so the shop honored there work and will take care of it.
Old Jan 13, 2021 | 10:02 AM
alloro's Avatar
alloro
That's a sign of a good shop!
outahere
Jun 17, 2015 10:38 AM
bryan_1980
Mar 10, 2007 05:12 PM
guillermorivera
Mar 20, 2005 09:36 AM
Stonewall74
1997 - 2003 F150
Feb 12, 2004 12:58 PM
mwkellner
Dec 18, 2000 10:27 AM
