How to test inner door handle
Old Nov 23, 2020 | 02:50 AM
jerryst's Avatar
jerryst
I can’t open the driver door from the inside. Is there a way to test if the whole door regulator needs to be replaced? Is there anything I should look out for? The inner door handle just spins.
thanks
jerry
Old Nov 23, 2020 | 08:50 AM
EBEAR's Avatar
EBEAR
Year of truck ? If it spins all the way around it's most likely the splines are stripped on the handle or possibly the linkage is broken but unlikely it is the door lock mechanism .
Old Nov 23, 2020 | 12:20 PM
CharlieLed's Avatar
CharlieLed
As EBEAR said, sounds like a stripped spline. I would remove the handle and inspect the splines on the shaft and inside the handle. I have seen many a truck on the road with a pair of vice grips as a handle.
Old Nov 23, 2020 | 12:53 PM
jerryst's Avatar
jerryst
Sorry my truck is a 1955 ford f100. The inner door mechanism to open the door just spins. So if I take out the mechanism I should see if it’s stripped. I saw on mid fifty they sell the spline stud. I guess I won’t know until I take it apart.
thanks
jerry
Old Nov 23, 2020 | 01:23 PM
56panelford's Avatar
56panelford
https://www.ford-trucks.com/forums/1...sn-t-work.html
Old Dec 4, 2020 | 08:38 PM
jerryst's Avatar
jerryst
Ok I took out the inner lock regulator. I tried to see if I could see why it keeps spinning. It seems like there is a spring clip that keeps it from spinning. But mine is not the case. The post keeps spinning. Is there a way to test and or take out the post? Or do I just need a door lock regulator?
thanks
jerry
Old Dec 4, 2020 | 08:41 PM
56panelford
It's pretty easy ...https://midfifty.com/instructions.php?ID=53
Old Dec 4, 2020 | 10:59 PM
jerryst's Avatar
jerryst
The spring that looks like hood spring is shot on my truck. The little spring is just hanging on. Maybe I will look for a rebuilt one.
thanks
jerry
jmcgee
Jan 16, 2012 01:33 PM
1998F250SC
1997 - 2003 F150
Oct 25, 2009 10:50 AM
Adamjr
Sep 22, 2009 06:25 PM
