Should I buy a Diesel?
The bad.......being new to diesel, one inadvertantly dumps DEF in the fuel tank.......or fill with gasoline.
The good.......AWESOME POWER!
The bad.........all the gasser guys are going to tell you the diesel will blow up 10 times per year.
The good........AWESOME, BLOW YOUR MIND POWER.!!!!!
So, as you see.......the good out weighs the bad
Buy one and enjoy the ride!
Oil changes are expensive 13 quarts @ $8 to $10 a quart
Fuel filters are about a hundo but you get 2.
Coolant is special and you need to have it checked for PH.
I would never trade my diesel for a gas truck. I do however work my truck. They don't like stop and go driving bad for emission systems. Be careful if you buy a used truck. Some have been deleted and most if not all don't come with a tuner. Easy to see. If the exhaust is a straight pipe than it's a delete and don't buy it. Many guys have bought trucks like this and nothing but problems. Buy a stock truck and modify it yourself that way you know what you have.
The item to focus on is your daily driving. Are you starting and shutting down a lot? Are you in a lot of stop and go traffic? These 6.7L engines are great but the emissions systems, when these trucks aren't worked hard a lot and sometimes even when they are, are an expensive pain to keep functional.
The 6.2L is a proven engine at this point but there is also the new 7.3L gas. Based on what you've explained, you don't need a diesel as both gas options will work fine with a correctly sized towing vehicle. However, if you want a diesel, go buy one, you'll like the truck a lot.
Diesel advantages: more power, and at low rpms, engine braking, better fuel economy, the ability to buy fuel at truck stops which when pulling long trailers is important.
Gas advantages, cheaper up front, cheaper maintenance, gas is usually cheaper than diesel
I would rather have a XL or XLT diesel than a fully loaded Lariat, KR or Platinum gasser. In other words if it come down to being able to afford the diesel option or a higher trim level I would take the diesel
My daily driving routine and area I live and drive in keeps my DPF functioning well. Most of my active regens get out close to 500 miles like they should as that's how the truck is programmed to do them. I also get some passive regens, when the exhaust gas temps are hot enough in the diesel particulate filter, where the soot burns off some without an active regen. That is due to the truck climbing up in altitude on the expressway at speed on the home. It builds up some on the way in to work though due to a downhill drive in.
I have a digital monitor which isn't a requirement but a guy like me likes to watch what's going on. I have a Banks iDash 1.8 that allows me to monitor 8 PIDS at one time. PIDS ( parameter IDs) like EGT (exhaust gas temps, ECT engine coolant temp, regen status off/active, soot load percentage (in the PDF), OLM oil life monitor, fuel pressure from the frame mounted DFCM (diesel fuel conditioning module aka primary pump at the HPFP (high pressure fuel pump), fuel filter and water separator) and OLM (Oil life monitor. But I chose those as they are many others I can monitor. It's also a code reader.
The 6.7 takes 13 quarts of oil. Some guys change at 5k, some at 6k to 6.5k miles and some like myself like the truck tell me when to change oil. The manual says to change fuel filters every 3rd oil change or by 22.5k miles. A lot here change them every other oil change. Since I monitor the fuel pressure, I now change every third oil change. I buy Motorcraft fuel filters on Amazon. Dieselfiltersonline.com also has good pricing as well.
About the power, it's great. Coming from a older gas powered truck, I love it. I don't have a camper yet but I can only imagine the how well my truck would tow. My diesel purchase was a choice as I didn't one. I wanted one. I also have plans for a snow plow for personal use.
As to DEF use, since I don't tow currently, I use about 2.5 gallons every 3k miles. Def fluid is cheap. I buy it at Wal-Mart in 2.5 gallon containers for under 8 bucks. 7 dollars and change without NYS sales tax. I don't drink anymore so I don't worry about putting DEF in the fuel tank.
I have a lockable fuel cap on so it's habit now when I fuel up to open my center console to grab the key for the fuel cap. I fill up at home with DEF but some purchase DEF at truck fuel stations so people have to be mindful of that. If you live in a cold weather region, you have to be careful of not overflowing the DEF tank to prevent the DEF tank neck from breaking if the DEF fluid freezes. I also use a Ford factory DEF nozzle to prevent DEF from overflowing and making a mess.I also use an additive every tankful of fuel for peace of mind but that's a personal choice. It's like asking what oil to run. Many different opinions here.
I threw a lot at you but wanted to present my POV. Welcome to the club here.
