2019 & 2020 SD Vehicle Security System - Ford Perimeter Plus
Old Apr 28, 2020 | 09:05 AM
Just Strokin's Avatar
Just Strokin
2019 and 2020 Vehicle Security System - Ford Perimeter Plus installation instructions for those interested,
It appears the VSS does include basic remote start similar to the old RF system on earlier 6.7L SD trucks. not sure if this works with the Intelligent Key (push button start) or not. I will have an idea soon as I am installing on my 2020 EcoSport with the Intelligent Key.
Yes, I know you have FordPass and it gives you remote start and more options but this remote start is part of the VSS as with the older SD VSS modules.
Description from Ford Accessories website.
Part No: KN1Z-19A361-A
SRP: $207.61
Use your factory key fobs to arm and disarm, helps provide contents protection too
When there’s sufficient impact to the glass or a body panel, the 2-stage shock sensor determines whether to issue a warning chirp or full alarm
When activated by your Ford Dealer, the Basic Remote Start System is also included; start your vehicle from up to 300’ away
Parking lights remain on during remote start so you know the engine is idling
Run time and other features are easily programmed through the vehicle’s driver information center
File Type: pdf
Old Apr 30, 2020 | 07:14 PM
The Bone's Avatar
The Bone
Wow it sure would be nice if some of these upgrades to security could be transferred to earlier SD's
Old May 1, 2020 | 06:53 AM
skidoomatt's Avatar
skidoomatt
I guess I'm missing it, but for those that already have remote start is this just adding somewhat of an "alarm" feature that would now be factory integrated instead of having to add it with aftermarket parts?
Old May 1, 2020 | 08:25 AM
Just Strokin
The VSS is the factory alarm system that is plug and play. As with previous versions for previous model years, part of the VSS is remote start by using a key fob or dedicated long distance remote start fob. So, whether you have a smartphone or flip phone or as with some, NO phone, you have the option of doing fob actuated remote start in conjunction with the VSS.
Also, you might be out in the boonies with no cell service with bad weather and want to remote start the truck so the wife's tushie doesn't get cold.
For instance, at my house and city, AT&T has very spotty service, T-mobile and some others have even less signal. Many city folk seem to forget not all of the owners with smartphones live where there is good cell service. With this, you have the option of remote start. so, think outside your box and about what kind of cell service have or don't have or whether they have a phone or not.
Old May 1, 2020 | 08:35 AM
Just Strokin
Bone, Ford does have the VSS for the ealier trucks. Most times people only talk about long distance remote start or the cellular remote start and no mention of the VSS.
Part No: DL3Z-19A361-A
SRP: $198.57
Perimeter Plus Remote Start Vehicle Security module adds an effective layer of anti-theft protection to your Ford vehicle. This new accessory contains features not available from the factory and is specifically designed to protect against the theft of contents and accessories in your vehicle.
  • No cut, no splice vehicle integration.
  • Adjustable, 2-stage shock/impact sensor.
  • Arms and disarms with the LOCK and UNLOCK buttons on the factory key, door-mounted keypad or with ignition key ON.
  • Upgrade to One-Way or Bi-Directional remote start. (requires basic remote start)
  • Upgrade to Remote Access. (requires cellular module and yearly subscription service)
  • May qualify for insurance discounts.
Can be found on eBay for around $100.
Old May 1, 2020 | 10:53 AM
skidoomatt's Avatar
skidoomatt
Ok, I think I follow. So someone like me who already has the factory remote start from the fob and also have the remote start from a smartphone (I do live in the boonies, but still have decent cell service) then this will simply add a factory alarm that will integrate with everything I already have?
Old May 1, 2020 | 11:24 AM
Just Strokin
I would think that is correct. I can't give you an answer that would say 100% yes. Not sure how Ford incorporated the remote start into the wiring/system for your truck since you have a key fob that initials remote start.
Old May 1, 2020 | 12:52 PM
skidoomatt's Avatar
skidoomatt
Ok, thanks for the info....this may be something I will inquire about through my dealer to see what they can tell me. I've never been a fan of aftermarket alarms due to having to cut in to the factory harness. If this is a plug and play, then it's may be worth the added bit of security features it offers.
Old Mar 24, 2021 | 02:06 PM
DEW34's Avatar
DEW34
Any one know if this will work on a 2021 SD ?
Old Mar 24, 2021 | 03:52 PM
speakerfritz's Avatar
speakerfritz
im confused
I have 2019 key fob remote start as well as the ford pass remote start.
do I have VSS and if I dont...why do I need it?
are we saying that my key fob remote start wont activate/deactivate my alarm system?
Old Mar 25, 2021 | 07:24 AM
Just Strokin
It should work on the 2021 as it will on earlier models.
Here is the 2021 instructions which are the same as the 2020.
https://www.fordservicecontent.com/F..._20_D1_002.pdf
Old Mar 25, 2021 | 07:32 AM
Just Strokin
Originally Posted by speakerfritz
im confused
No, you do not have VSS with the fob remote start/FordPass remote start.
The VSS is similar to the Viper or other car alarms. You do not have any alarm system with the fob remote start key.Use your factory key fobs to arm and disarm, helps provide contents protection too
  • When there’s sufficient impact to the glass or a body panel, the 2-stage shock sensor determines whether to issue a warning chirp or full alarm
  • When activated by your Ford Dealer, the Basic Remote Start System is also included; start your vehicle from up to 300’ away
  • Parking lights remain on during remote start so you know the engine is idling
  • Run time and other features are easily programmed through the vehicle’s driver information center
do you need it? That would be your choice. I added it to my 2015 for the long distance remote start and got the alarm part as a bonus.
Old Mar 25, 2021 | 09:46 AM
DEW34's Avatar
DEW34
I had it on my 19 worked good was just trying to confirm that some one has actually used it on a 20 or 21 SD.
Old Mar 25, 2021 | 05:30 PM
Just Strokin
Might not be anyone on this site using it. I suspect there are some using it in the real world since it is plug and play.
Old Apr 15, 2021 | 12:45 PM
DEW34's Avatar
DEW34
I can say it works for sure in a 2021 xlt tremor , the install instructions were a little cryptic only because they have a lot of other vehicles on the inst and only mention a SD one or two times . But they helped for sure !! lol even remote start works thru the fob thanks Just Strokin for the help .
