4 speed doesn't want to go into 4th.
Old 10-15-2003, 06:55 AM
jpb222's Avatar
jpb222
jpb222 is offline
Ocasionally, mostly in the moring on my trip to work while the truck is still cold, when I try to shift into 4th the gears grind and it won't let me in. I have to put it back into 3rd and then try again. It is like the syncros just quit working for an instant. It only does this once then the truck is good for the rest of the day
Does this mean that my syncros are going out or is it just a trait of of the 4-speeds when they are cold?
I just put the tranny in and don't want to tkae it back out to re-build it.
Old 10-15-2003, 08:08 AM
neverenough's Avatar
neverenough
neverenough is offline
I have never had a tranny do that to me, but, if it doesn't make a "howling" noise I don't think it would be muck of a problem. BTW what oil does it have in it?
Old 10-15-2003, 08:31 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Moved to proper forum
Old 10-15-2003, 09:31 AM
jpb222's Avatar
jpb222
jpb222 is offline
I think I put 140 wt oil in it.
and no it doesn't howl at all. except for in reverse and first but think that is normal for compound gears
Old 10-16-2003, 03:15 PM
armyguy's Avatar
armyguy
armyguy is offline
try this: before you take off, go through all the gears before you let the clutch out, maybe that`ll line it up (just a thought)
Old 10-16-2003, 09:13 PM
jpb222's Avatar
jpb222
jpb222 is offline
I put a lighter gear oil in (75W) and it works great now.
I guess the heavy gear oil was not providing enough friction to have the syncros grab the gears properly. there were probally just slipping.
I can now even downsift into 2nd at a higher speed!!!!!
Old 01-14-2004, 04:29 PM
jpb222's Avatar
jpb222
jpb222 is offline
well now that is is below freezing it is doing it again.....so I have been letting the truck warm up for 5-mins before I drive and that has been fixing it but I wonder if my syncros are going out?
Also if it does sound like syncros is there an "easy" way to change them with the tranny still in the truck?
I pondered lifting the engine part way out......enough to slide the main drive gear out a little and taking the t-case off to pull the main shaft out a little..... anyone ever done this?
guppy
10-07-2021 12:37 AM
7.3 forever
30
08-14-2014 08:35 AM
Mitch1407
09-21-2012 04:24 PM
Corn
03-31-2010 11:36 AM
Quick Reply: 4 speed doesn't want to go into 4th.
