Different head castings, same engine.
The passenger side is:
C2SE 8090
and the driver side head is:
C3AE 6090C
from what I can see online and I’m not saying that it has to be right is one of my heads is a 390 head and the other is a 406 head. My question is how did this work wouldn’t one side have a completely different compression ratio not to mention other problems? Would I be better off to get another set of heads?
thanks.
Driver side
Passenger side
Have you searched out each number and that's how you got the compression ratios? They may be different just due to a difference in engine stroke, or deck height, or piston design, or whatever. So Cc'ing is the only way to know for sure.
However, if they look different, then there's no way they should be working together on the same engine. Someone did a valve job or something in it's past and swapped in a head mistakenly.
I found the same thing on my brother's '66 Corvette 327 many years ago. Both heads were different part numbers for the same engine series (327ci - 300HP) and would have been found in Corvettes of only slightly different build months. It's possible they were in the bins at the same time even, but they were not the same exactly.
Good enough that the engine ran passably well, but any imperfections could have been a result of the two different types. So I found a matching head for one of them and used the pair. Still have the old "wrong" head 35 years later too! I'm really bad about selling stuff on....
Good luck. Hopefully it works, or getting a new one is a quick-n-easy fix. But personally I'd want the part numbers to match.
Paul
C2SE-A is a 62-63 390 6v 390 HP head, 66-69cc, 2.02/1.55 valves, 1.34x1.93 intake port, 1.28x1.84 exhaust port, 6v or 4v w/ flat top pistons
C3AE-C is a late 63 406 6v head, 57-61cc, 2.09/1.66 valves, 1.34x2.34 intake port, 1.28x1.84 exhaust port, and has machined spring cup seats.
I'd try to come up with a pair of heads, D2TE-AA, C6AE-R or C8AE-H are all pretty common and good heads (D2TE's have induction hardened seats for unleaded) and relatively cheap.
Then clean up your heads and throw them up on a FE or Galaxie page for someone looking for a single and flip them. OOORRR try to find your own matching pair for each and build some cool engines.
