At a loss for MPG
Old Jan 4, 2020 | 04:06 PM
mjtpolice76's Avatar
mjtpolice76
At a loss for MPG
This truck is driving me nuts. My fuel mileage is way down used to get 15mpg towing 8k and 18 unloaded on the highway with stock injectors. I install 180/30’s now I get 10 towing 14 unloaded. No boost leaks checked that with diesel site leak detector, no fuel or oil leaks no brakes hanging up or bad hub bearings I checked those. Could my my 38r not providing enough air to feed these injectors? I’m about ready to sell this fuel pig and buy a gasser. Two different tuners with same results. Any suggestions or help would be appreciated.
Old Jan 4, 2020 | 04:21 PM
Wes444's Avatar
Wes444
Well if you are solely chasing MPG and think a gasser will solve it, be prepared to make a very expensive mistake. Hop over to the towing forum and read the threads there. Gassers never report more than 10mpg towing, mostly 6-8. And empty they get less mileage than us too. But, they are cheaper to work on and oil changes don't require multi gallons or huge filters.
Old Jan 4, 2020 | 04:22 PM
kbeefy's Avatar
kbeefy
Are all other parameters the same? Load/trailer/speed?
I don't know where you are but I have lots of people complain about poor winter mileage then find out that they let their vehicle warm up 20 minutes each day and drive in 4x4.
Old Jan 4, 2020 | 04:27 PM
kbeefy's Avatar
kbeefy
Originally Posted by Wesley Green
Well if you are solely chasing MPG and think a gasser will solve it be prepared to make a very expensive mistake.
Customer was in yesterday super happy about the new to him Dodge 2500 w/5.7 gas.... except mileage. 10-14 empty and he says he drives very easy.
I like to check different trucks MPG average on the Lie-o-meter if equipped. I rarely see 14+. Most of these include warmup and city driving, not just driving from one fillup to the next and calculating actual mileage.
Old Jan 4, 2020 | 04:45 PM
mjtpolice76
The trip up with trailer, filled up just before entering highway. and filled upon arrival to get actual mpg hand calculated. Same coming back unloaded. It’s not the winter fuel I’m taking that into consideration I would loose about 2 mpg between summer and winter blends. Can it be the turbo just not feeding enough air? I just can’t figure this out. All parameters the same but these remain injectors 70 mph on cruise the whole way.
Old Jan 4, 2020 | 06:18 PM
kbeefy's Avatar
kbeefy
I would think if you had a boost or air issue you would see black smoke.
180/30 is not that much bigger than stock, did you also change tunes? Sorry I'm a bit rusty on which injectors require a change in tunes to run.
Old Jan 4, 2020 | 06:23 PM
mjtpolice76
Yes. Changed tunes twice two different tuners
Old Jan 4, 2020 | 07:05 PM
Colorado350's Avatar
Colorado350
Any play in your turbo? How many miles on the air filter?
Old Jan 4, 2020 | 07:06 PM
mjtpolice76
Air filter clean I would have to check turbo ?
Old Jan 4, 2020 | 07:24 PM
Colorado350
Well, if the turbo has play it’s not working at peak efficiency.
Old Jan 4, 2020 | 10:57 PM
mjtpolice76
I’ll check turbo tomo I hope that’s the problem because I have been eyeballing a KC300x turbo
Old Jan 5, 2020 | 08:47 PM
dmd's Avatar
dmd
Check the thermostat too. Mine was broke and wasn't getting the engine warmed up, found the issue because the pump seal started leaking. Now
heater works better (wasn't bad before) and gained 2.5-mpg, and I live in Tx where it doesnt get real cold.
Old Jan 6, 2020 | 03:43 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Is it not from the looser spray of the bigger nozzles?
Celtictexan
6.7L Power Stroke Diesel
36
May 7, 2018 04:01 PM
sgeorge
6.2L V8
Jan 27, 2017 01:40 PM
Davidvc1964
Jul 5, 2013 02:59 PM
matthewadams
Jun 23, 2007 06:41 AM
tristankc
May 30, 2005 06:24 PM
