Universal Master Cylinder and Brake Booster
Old Dec 27, 2019 | 12:36 PM
jos180's Avatar
jos180
I installed a universal master cylinder and brake booster into my 1955 Ford F-100. Everything was working fine until yesterday when all four wheels locked up. A small amount of brake fluid leaked from the lid of the master cylinder. I broke the seal between the master cylinder and brake booster which released the brakes. One I tightened it up again the brakes locked. I think I have a bad brake booster but I’m looking for advise.
thanks,
Jon
Old Dec 27, 2019 | 12:57 PM
EBEAR's Avatar
EBEAR
It sounds like your pushrod is too long and not allowing the master back enough . Where is your booster mounted , 4 wheel discs and do you have a residual valve ?
Old Dec 27, 2019 | 01:35 PM
ben98gs's Avatar
ben98gs
I second the pushrod length. I too swapped out the master cylinder on my truck this fall, took it on a few test drives and everything seemed fine. First longer distance trip my brakes were dragging bad. Got to my destination and noticed that the brake lights were also staying on, which meant the sensor right at the back of the master cylinder was sensing pressure. A few turns backing down the pushrod to the master and everything has been fine since!
Old Dec 27, 2019 | 02:34 PM
jos180's Avatar
jos180
That makes sense. Can I put a couple washers between the master and the booster?
Old Dec 27, 2019 | 02:36 PM
jos180's Avatar
jos180
Or make a heavy gasket.
Old Dec 27, 2019 | 02:58 PM
56panelford's Avatar
56panelford
Take the master cylinder off the booster, the length of the pin from the booster can be adjusted for length ..no need to disconnect any brake lines in case you're wondering..
Old Dec 27, 2019 | 03:47 PM
jos180's Avatar
jos180
How do I adjust it?
Old Dec 27, 2019 | 03:52 PM
jos180's Avatar
jos180
Old Dec 27, 2019 | 03:58 PM
56panelford
It is a threaded sleeve, you should be able to just screw it in. Here's a link to a thread where John Niolon had a problem when it wasn't long enough. It may be of some help
https://www.ford-trucks.com/forums/1...akes-dont.html
Old Dec 27, 2019 | 04:02 PM
jos180's Avatar
jos180
Great info.
I got it figured out. I really appreciate the help!
Jon
QUOTE=56panelford;19022513]It is a threaded sleeve, you should be able to just screw it in. Here's a link to a thread where John Niolon had a problem when it wasn't long enough. It may be of some help
https://www.ford-trucks.com/forums/1...akes-dont.html[/QUOTE]
Old Jan 14, 2020 | 01:44 PM
jos180's Avatar
jos180
Turns out I don't have it figured out.
After I adjusted the push rod brakes were working well. I started my truck the other day just to move it so I could sweep my garage. It sat running for about 10 minutes. When I got back in the truck to put it in the garage, the brakes were locked up. I loosened the bolts that hold the master cylinder to the booster just two turns and the wheels freed up. I removed the master cylinder completely to look at the booster again more closely. I have the push rod as short as it can go. There is no pressure on the brake pedal clevis. Then I noticed that after I push in and release the brakes the push rod did not return all the way. It stuck out maybe an 1/8" and I could push it in with my finger. I think this is the real problem. It is a brand new booster. I hit it with a shot of WD40 but it is still sticking. Can you rebuild a brake booster or is there another way to remedy something like this? Or do I need to buy a new booster? I really would prefer using the brand new one I have. Thanks for the help in advance.
Jon
https://www.ford-trucks.com/forums/1...OTE][/QUOT
eknight
Dec 28, 2019 08:53 AM
Beast12
Jun 5, 2005 12:13 AM
White73390
Nov 15, 2003 07:55 PM
