Question on tuning while towing
Old Sep 3, 2019 | 07:11 PM
alaskapilot95's Avatar
alaskapilot95
Hey guys haven’t been on here in a while. I have been hauling water a lot lately since we’ve had such a dry year. I have been using the 1023 tunes and have been using the Cummins killer tune as it has the best power getting up the hills and such around here. Is it ok to use the tune for everything or should I be using the towing tunes? Just don’t want to hurt the truck and egts have been staying below 1200f
Old Sep 3, 2019 | 08:03 PM
Walleye Hunter's Avatar
Walleye Hunter
I don't see how it could hurt the truck if you keep your EGT's in check, mine is live tuned and I can't turn it off.
Old Sep 4, 2019 | 07:09 AM
Tugly's Avatar
Tugly
I had some 1023 tunes in the truck I bought before he was Frankenstinky. They do a good job of keeping things reasonable in there - so it's really a matter of having the EGT probe on the exhaust manifold elbow to make sure it's accurate. I would personally add the second EGT gauge on the passenger side for a second opinion while towing in a race tune.
Old Sep 4, 2019 | 03:22 PM
alaskapilot95
Ok thats about what I was figuring. I wouldn't mind getting a second egt gauge but it would be another $150 or so. Wish I could get a edge monitor or something but money doesn't allow that right now. Most the time I can keep the Egt's in the 1000-1175 range pretty easily. Ive been hauling 1,000 gallons of water roughly 8,000lbs just of water. Probably just over 20,000lbs loaded.
Old Sep 4, 2019 | 04:11 PM
brian42's Avatar
brian42
Veteran: Navy
What Walleye Hunter said. Tunes were made with certain situations in mind but you can run any tune you want any time you want as long as you keep your parameters in check.
qwertmonkey
Feb 19, 2017 11:33 AM
DesMoinesDieselDuty
Apr 25, 2012 02:22 PM
gvandyke
Oct 18, 2007 12:25 AM
Fire Rooster
Apr 5, 2004 10:13 AM
