no brake pedal pressure
I replaced calipers, brackets, disks and pads......
I have been through the bleeding process and here are the results.....
1. some air and then a small "dribble" of fluid from both front
2. no air and great flow from both rear
3. removed lines from calipers and only a dribble of fluid on both fronts
4. pedal goes all the way to the floor and creates a "noise" in the engine compartment like the PS pump is low on fluid
5. can not get pedal pressure
6. filled the PS reservoir but found it empty after bleeding process
7. found hose from master cylinder to PS pump.. Is the fluid from PS to MC the same?
8. I have been using brake fluid in Master Cylinder and power steering fluid in PS pump
9. I found that I should be using ATF in the PS unit
10. Should I be using ATF in the master cylinder?
11. Is there a "modual" of some sort in the brake system that requires bleeding via access to the computer?
My first diesel and first 4 wheel disc.... I am getting a real edumacation on this one.... HELP!
The advantage of using a pressure bleeder is that you can fill the bleeder with a lot of brake fluid and then you don't have to worry about running the reservoir dry.
Our trucks use hydroboost for brake assist and that uses hydraulic pressure from the PS pump. The fluid used in there is ATF. Do NOT use conventional power steering fluid. A lot more stuff to talk about but I have work to do. I'll be back if others haven't chimed in by then.
I have added PS fluid in the PS pump but I will do a flush on it with ATF, Perhaps I have a PS system leak.... could that contribute to the "no pedal" condition.
As far as the response is concerned, I won't be in a panic until the first snow flakes so I'm good for the moment.
Thanks again.
And just for reference, what is "bench bleed"? I assume it means taking it off the vehicle and completely emptying it.
thanks
That booster with PS fluid going to it is the HydroBoost I was telling you about.
That's the ABS module with all the brake lines going in and out. Unless brake hydraulics completely ran dry, you don't normally have to bleed that. It wouldn't hurt though.
As for the ABS module which is the piece behind the driver side headlight, @dmueller71 just went through this. He found some instructions online which I believe he plans to post here soon and he took some video of the process.
I hope to include both the instructions he found and his video in the 7.3L PSD Tech Folder soon.
I filled the PS pump and let it sit for the last couple of days and the level did not change. Of course that's not under pressure but it's a good sign.
I'm still having trouble identifying the power booster. I see where the hose goes from the PS pump up to the MC. Does the PS fluid go into the MC and then to the power booster somewhere on the other side of the firewall. Like inside, under the dash? I've seen diagrams where the power booster operates on a vacuum but I don't think my is like that.
If I fill the MC with brake fluid and disconnect the 2 lines at the "block" behind the headlight, can I then bleed the MC that way instead of removing it from the vehicle?
thanks
Broken positive battery cable
Black and red probes pointing to the ends of the broken cable
Behind the MC left
Behind the MC right
Behind the MC top
Hose from the PS pump to the MC
PS pump and hose to MC
The solution to fix 'my' issue after talking to a few people was to replace all of the rubber brake lines. After 18 years the lines have degraded to much on the inside the debris was hindering the flow of fluid 'out' of the brake cylinders and keeping the brakes engaged. I also replace a couple of metal lines. I blew the remaining metal lines out to make sure that no debris was in them. As you know the brake fluid will 'peel paint', careful when blowing out lines. My jack stands are now very 'spotted' in colors.
There is a reason the calipers are sticking (out). Your slide pins may have not been cleaned and greased as often as they should have.
