35 x 12.50 x 18 tires on 04 F350 rubbing front leaf springs
Just picked up a 04 F350, the previous owner put oversized Ford rims and tires on the truck from a later model Ford. The tires look great on the truck but I can only turn about 1 1/2 turns on the steering before I have tires rubbing on leaf springs. Is there anyway to fix this without replacing the tires?
Yes, if running OEM wheels be sure to use hubcentric spacers, avoid any non-hubcentric (or lugcentric) spacers as both the wheels and your truck were designed to work correctly with the factory hubcentric arrangement. The wheels have about 1.75" of a difference in their design but using 2" thick spacers will save you from having to trim the ends off your trucks lug studs.
The choice to use either steel or aluminum is yours, just be sure to keep everything properly torqued once installed.
I run 35"x12.8" tires on my OEM '04 18"s on my '05 (same leaf spring front suspension as your '04) EX had still have just a little tire on spring rub at full lock.
Yes, this is the same truck. No, I'm unsure of how I would do that. It appears I was mistaken about the turning radius. Without spacers at 1.5 turns is about as tight as I can turn, with the spacers I can do a full 2 rotations of the steering wheel.
Most trucks are about 4-5 turns from full left to full right. If you're getting 2 turns from center to full left, or full right, you're where it should be. The 99-04 trucks have a more limited turning radius than the 05+ coil sprung trucks because of the leaf springs. Backspacing is critical to get everything to fit correctly.
Okay, well I eliminated almost all the rubbing. The tires seem to still rub slightly when turning on the rear of the fender liner, I'll look at it more to see if I can pull them back any further then they already are with the cable ties. Seems like turning left I have 1 3/4 turn and right turns I can get almost 2 turns. Just glad to be able to finally drive it.
farva66
08-26-2014 06:36 PM
rad1026
16
04-01-2010 01:49 PM
