What clutch ... plus other engine advice please
So my 86 F150 4x4 sound like it has marbles in the engine ... bottom end is gone ... odometer says 47K ... probably 247K
Only paid $1K for the truck with a plow 5 years ago ... lots of fiberglass and body filler but it still passes inspection each year.
I just got an engine today .... $400 plus $100 shipping.
So, before putting it in, I want to do anything I "should" while the engine is out.
First, a new clutch .... which one? RockAuto has kits from $55 to $120 ... Two questions: 1) how do I know if I have a 10" or 11" (they list both for my truck 2) is one any better then another?
Next, any other parts I should put in? I was thinking maybe a new oil pump and a new gasket set (real main, pan, ...)?
Anything else I am missing that I should do now (obviously new oil, filter, spark plugs, ....)?
Thanks .... Mike
Might want to get your flywheel cleaned up if you have a shop close by that can do it.
How is the input shaft seal in the transmission? If you were going to change it, now would be a good time.
PS: While my '84 302 flywheel had the holes for the larger 11" clutch, I'm not 100% certain that they all do. I assume yes, at least in the years after my truck, but maybe somebody else on here can confirm this.
When you take the oil pan off, stick your finger up by the timing chain in the front and see how loose it is. If it's never been changed it's overdue. That means pulling the front of the engine down to replace that, I would not skip this step, the chains are notorious for wearing on these engines.
If I am right ... and I have never had a 300 apart .... doesn't it have just timing gears and no chain? This s one of the items I am thinking of changing .... I was told (but not sure how correct they are) the factory one is plastic and after 33 years it is probably worn?
Mike
You going to put new bearing inserts in it?
Check the oil pump for wear.
This is exactly what I arguing with myself over.
I just took the engine to the guy who is flipping it for me. I would do it but I don't have a workshop yet (just a concrete pad a present).
He wants to just shove it in the way it is.
I am thinking of putting in a "freshen up" kit ... bearings, rings, gears, oil pump, ....
He says I am asking for trouble but I think it would be wise to do while the engine is out.
Thinking, thinking, thinking, ....
Mike
Installing a used engine without checking anything is a gamble.
Likewise, opening up a used motor invites a bigger project, sometimes leading to way more than you asked for.
Watch a couple "Roadkill" videos, where they clean out the mouse nests, hit it with a little starting fluid, add a turbo and motor on. You'll feel better no matter which way you go, as it will be easy to rationalized whatever action/inaction you take.
Serving suggestion.....
Being the same year as yours could it have the same miles?
Was it rebuilt and if so then how many miles?
Does it look like it has been leaking oil since it rolled off the factory floor?
If all are not bad then I would just do the oil, side cover & valve cover gaskets and call it done.
My project trucks motor did look like it was leaking oil since day 1, had no clue the miles, none of the gauges worked and had a miss when running.
On the short test drive the dead hole did come to life for a short time so I thought motor was some what good.
Did a compression test, was good, so a set of new plugs and it ran great.
I pulled the motor, cleaned it and replace the pan, side cover & valve cover gaskets, painted and put it back in.
Doing this I did find this motor was replaced from a newer car or truck as it had some gray paint.
When you do the motor swap I would hold on to your old motor to rebuild down the road.
If not in a rush because the truck is running you can rebuild it in steps. Do the head and store it then when you have the $$ do the block and you then have a complete rebuilt motor.
Dave ----
Since these trucks only have 5 digit odometers, it could be 46K, 146k, 246k, ....
I got it from a yard 6 hours away .. they pulled and shipped it.
They "said" it was running good ... said they drove the truck around the yard.
For $400 and $100 shipping, I had nothing to loose.
I just got it ...still in plastic. Going to rain for two days, so I will leave it wrapped ... take a good look at it on the weekend.
thanks ... Mike
