1986 F250 460 running hot
Old Aug 8, 2019 | 05:54 PM
TheRev's Avatar
TheRev
So, I think my 86 is running hot (it just feels that way). I can't really tell because the temperature gauge doesn't work.
Coolant is circulating, as the hose feels hot.
Any ideas on where I should start? I wouldn't mind having a working gauge, but I don't know how to tell if the gauge is shot, the wiring isn't working or the sensor is done. Plus the gauge obviously wouldn't be the cause of it running hot, so any other ideas would be nice...
Old Aug 8, 2019 | 07:41 PM
Franklin2's Avatar
Franklin2
Go to harbor freight and buy one of these for $27.00. Or go buy a aftermarket gauge from the parts store and mount it under the dash. You can waste a lot of money going by what you "feel".
Old Aug 8, 2019 | 09:22 PM
TheRev's Avatar
TheRev
You don't recommend trying to fix or replace the original gauge? Because I have no issues with doing the extra work if necessary.
Old Aug 8, 2019 | 11:32 PM
kramttocs's Avatar
kramttocs
I would but I don't care for under the dash gauges. Start with the sending unit and work your way to the dash unless you already know the part that's bad.
BUT... it is very nice having a numerical value as the built in gauge doesn't really tell you much. You could always get an under the dash unit temporarily and still fix the stock one. The added benefit being that you'll know what the value is of the stock unit if you run them together for awhile.
Old Aug 9, 2019 | 06:46 AM
Odisvan's Avatar
Odisvan
does rust come out of your radiator when you drain it?
Old Aug 9, 2019 | 08:59 PM
Franklin2's Avatar
Franklin2
I do not. What is "normal" temperature? What is "normal" oil pressure?
Old Aug 9, 2019 | 09:48 PM
TheRev's Avatar
TheRev
Not the last time, but it has been a while....
Old Aug 28, 2019 | 12:06 AM
TheRev's Avatar
TheRev
Well I tested the wires and the gauge, and they were fine. The sensor was out. Easy fix! But it is definitely running hot. Way hotter than before (I've had this truck a while) I flushed and replaced the coolant and it was fine. Still hot. Any other thoughts?
Old Aug 28, 2019 | 05:54 AM
Franklin2's Avatar
Franklin2
What evidence do you have that leads you to believe it's running hot?
Old Aug 28, 2019 | 08:23 AM
kr98664's Avatar
kr98664
+1 on that. Beg, borrow, or steal an infrared thermometer. You can get an El Cheapo brand for $25 or so that will work just fine. You are working blind without one.
With the engine fully warm, measure the temperature of the thermostat housing and tell us what you've got. That will help determine whether you've got an actual overheating issue, an indication problem, or a combination of the two.
