Greasable vs non front ball joints
Old May 22, 2019 | 09:37 AM
brannman's Avatar
brannman
Based on experiences here on FTE and in the Tech folders, I'm looking at sourcing Spicer ball joints from Venture (Spicer Ball Joint Kit) but they look to be sealed rather than greasable. I'm confident that the Spicer joints will last a long time without needing service, but my gut tells me that I'd be more comfortable having joints that are greasable. Are there greasable Spicer joints available?
Old May 22, 2019 | 10:15 AM
Flyboy1100's Avatar
Flyboy1100
i'm fairly certain my non greasable oem ball joints came out at 173k when i replaced them with new non greaseable spicer ball joints ......
Old May 22, 2019 | 09:32 PM
Bently_Coop's Avatar
Bently_Coop
I replaced u-joints with non greasable and the local driveshaft shop said they are the same, one just has to be greased constantly where the other doesn't.
Old May 23, 2019 | 05:29 AM
Flyboy1100's Avatar
Flyboy1100
They aren’t the same, one is also hollow
Old May 23, 2019 | 08:10 AM
brannman's Avatar
brannman
OK, I see that I I didn't make my post clear enough. I'll restate. Are sealed Spicer ball joints reliable enough over time/miles as sealed units to be preferable to/ better or as good as servicable/greasable ball joints?
Old May 23, 2019 | 09:47 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Real, and I say real Spricer because there are Chinese knock offs of spicer ball joints all over ebay and amazon….beware and only buy from known trusted sources like Ventures.
yes a genuine Spicer ungreasable ball joint is vastely superior to most greasable units of other brands, the only reason to make a BJ greasable is because it cost less to add a grease fitting then it would have cost to machine tighter toleranses and sealing methods. Spicers can be hard to find and cost more is why I imigaine people try other brands but it is a huge mistake in my book. fwiw, motorcrafts are Spicers and your trucks entire front axle including the Ball Joints were made by Spicer….. stick with Spicer ( and Timken for bearings )
Old May 23, 2019 | 11:36 AM
brannman's Avatar
brannman
Thanks. I have Ventures on the hook for the L/R set of ball joints, just wanted to get feedback. I'm also R&R'ing the unit hubs/bearings and rebuilding the outer axle shafts with the kit from Ventures. I sure as hell don't want to do ball joints again anytime soon after this....
Old May 23, 2019 | 04:23 PM
pirate4x4_camo
be sure to remove the upper BJ sleeve and get it clean on both sides as well as the bore in the knuckle, I think this is where many people who run into "memory steer" go wrong by not getting that sleeeve and knuckle squueky clean.
Old May 23, 2019 | 05:45 PM
JuanHuevos's Avatar
JuanHuevos
I wish I had read this before I replaced mine. I did mine 2 weeks ago and used XRF greaseable. Also replaced my Timken hubs at the same time. The Timkens only lasted about 4 years and 40k miles. I had greased those hubs using the ABS hole but it didn't make a difference in the end. I didn't grease the new ones in that way.
Old May 24, 2019 | 12:45 AM
ESV's Avatar
ESV
Glad I read this tonight. I was getting ready to order a greaseable brand. I'll now be ordering the Spicer brand ball joints from Venture. Thank you for the solid advice.
Old Apr 12, 2020 | 06:25 PM
FSJ-EARL's Avatar
FSJ-EARL
Spicer.....
Club Wagon
1997 - 2003 F150
21
May 3, 2013 10:03 PM
wallz
Sep 29, 2011 04:46 PM
crashed13
Feb 23, 2006 02:28 AM
fowlerford56
Sep 9, 2004 09:00 AM
ObiWanJak
May 19, 2003 02:01 PM
