87 f 150 no power to fuel pump!
Old May 16, 2019 | 08:02 PM
Pixel123's Avatar
Pixel123
I have an 87 f 150 4.9 l standard shift that died all of a sudden. When I turn the key the fuel pump doesn’t cut in. I have zero fuel pressure according to gauge. I removed external fuel pump and manually wired it and it operated fine. Fuel pump relay clicks and meter reads 12 v coming from relay. At initial switch I cannot lot read a voltage or at fuel pump connections.still no voltage. Is it my inertia switch gone bad or can I bypass. Thanks any ideas?
Old May 18, 2019 | 06:53 AM
EPNCSU2006's Avatar
EPNCSU2006
Start tracing the wiring from the relay to the tanks. Are you forcing the relay to turn on through the diagnostic test port under hood, or just turning the key? The inertia switch connector had melted partially on my truck many years ago. I don't know if it ever stopped working but it definitely got hot at some point.
Old May 29, 2019 | 11:38 AM
LxMan1's Avatar
LxMan1
You should have power on at least one side of the inertia switch for a couple of second when you first turn the key on. If not, the problem is upstream.
paulwjax
Mar 26, 2014 11:21 AM
1990f1504x44.9
1978 - 1996 Big Bronco
Dec 18, 2006 11:10 PM
Brewer51
Bronco II
Oct 13, 2006 03:36 PM
Ty_Yota
Apr 5, 2006 12:43 PM
Ed_B1
Nov 21, 2003 12:50 PM
