What size is the dash speaker?
Old May 13, 2019 | 03:17 PM
El Caballo's Avatar
El Caballo
Is the dash speaker 5x7 or another size?
Old May 13, 2019 | 03:31 PM
smle's Avatar
smle
That's about right. The one LMC sells is pretty much direct fit. The fiber cushion, spacer what ever they call it, needs to b.e 3/8 to 1/2 inch thick. Otherwise the center of the speaker will contact the dash.
Old May 13, 2019 | 03:34 PM
Mark8man's Avatar
Mark8man
Just went through this. Its not a standard 5x7. Seems more like a 4.5 x 6.5 but depends where you measure from. I was able to shoehorn a 5x7 in my 77 but had to modify the speaker and the opening slightly around the offset. Not visible once the grille is on but I don't know if I would do that again knowing what I know now.....but had already bought the speaker so made it work. Maybe someone will have a guaranteed plug and play solution but I hadn't seen one with a little searching.
Old May 13, 2019 | 04:16 PM
smle's Avatar
smle
The one I got was a direct fit with the exception mentioned in the prior post. It went into a 78.
Old May 13, 2019 | 04:29 PM
DB429SCJ's Avatar
DB429SCJ
It's listed in the parts catalog as a 5 x 7.
Old May 13, 2019 | 07:52 PM
440 sixpack's Avatar
440 sixpack
more importantly you need the correct ohms if you have an original radio. if you use a newer speaker on an older radio you'll toast the radio.
6t6merc
Dec 27, 2013 08:11 PM
rusbukt
Jul 8, 2012 05:37 PM
johaner78
Dec 4, 2010 12:53 PM
Slinkyram
Mar 28, 2007 08:39 PM
dotcentral
Nov 22, 2003 02:10 PM
