Coolant Pressure and Cylinder Head Options
I can get the truck up to 16 PSI pretty easily with some wide open runs. One thing I've noticed is the truck does NOT like to build pressure when it's cold. For example, I can give it some good throttle while it's still relatively cold, coolant temp between 100-160, and the pressure doesn't rise much, if at all. But when the truck is fully warmed up, ~190 ECT, you can clearly see pressure rising with throttle.
Here's some of my theories on how you can build excessive cooling system pressure:
#1 The obvious, bad head gaskets: combustion gasses escaping into the cooling system and travelling up to the degas bottle.
#2 If your water pump was sucking air (which it shouldn't be), that air would make it up to the degas bottle, and with a fixed volume, would create pressure.
#3 A cracked cylinder head, again letting combustion gasses escape from the chamber, through the head,and into the cooling jackets in the cylinder head.
I'm guessing my truck has either problem #1 or #3. Note my driver's side cylinder head has been repaired with accurate diesel's repair kit, to prevent fuel breaching into the coolant. So, I KNOW there is a crack in the head - I just don't know where it starts or ends. For those not familiar, you basically install a longer sleeve into the injector bore to seal off the crack. With the repair, the fuel is contained within the new sleeve, and not within the head, so there is no contamination.
This leads me to my last question. What's my options for cylinder head repair? Unless someone can convince me my truck doesn't have blown head gaskets or cracked heads, the engine is coming out and getting new lifters, push rods, and head gaskets (truck has 370k). I'd like o-ringed heads, hardened valve seats, and the heads obviously decked flat within spec surface finish. The rest I could give a hoot about. Not looking for performance valve springs or anything. The only problem I have with buying remanufactured ford heads is that the cylinder head cracking between the fuel gallery and the coolant passage is a design flaw that can't really be fixed. The only fix I've seen for this is thicker castings (coming from China). The only good heads coming from China seem to be Kill Devil Diesel's heads, which aren't China price. They're $2300. I definitely don't want to reman my head with the crack - that head is junk. So there goes my core charge. Yeah, Southeast Cylinder Heads offers a lifetime warranty on their heads - but if I put their head in and it cracks after a few years, giving me fuel in the coolant again, I'm going to be on the hook for the labor. Yeah they'll send me a new head, which is awesome. but... yeah. What's my best options as far as cylinder heads go, I don't have endless pockets either. UCF, southeast, and kill devil are all in the $2100-2300 range. It looks like I might be picking from those 3 but the chinese castings do bother me even though they have great reviews.
Discuss below please!
I'm pretty confident in the stoutness of the bottom end, pistons, and cylinder walls on these trucks. My heads were off at 270k and the tech said the cross hatching looked brand new. If i see something concerning, I'll address it, but for right now - I'm just planning on addressing the top end and reseal the engine.. and new lifters. cheap insurance.
bismic, yes i agree - and all 3 of those options are around the same price
6.0L Ford PowerStroke NO CORE Heads - $ 2150
6.0L PowerStroke® Diesel O-ringed Heads
NO CORE
- Total online price $2,350 for pair of heads shipped within the Continental US* (excludes applicable taxes)
- Optional porting and polishing only an additional $600
- Optional 2 Victor Reinz Head Gaskets for only $150 more
- Optional ARP 2000 Head Studs for just another $475
- Optional 110lb performance valve spring $350
All heads have had the following remanufacture operations completed:
• Completely disassembled
• Thermal cleaned and shot blasted
• Magnafluxed for cracks
• Cooling system pressure tested
• All valve guides replaced with oil retaining spiral core guides
• All intake valve seats replaced, using high grade cobalt/iron inserts
• All exhaust seats replaced, using nickel, cobalt non-magnetic inserts
• Cylinder # 4 & 5 injector holes sleeved to prevent "fuel in coolant issue"
• The remaining 6 injector cups are replaced with new Ford cups
• All glow plug sleeves are replaced with new Ford sleeves
• The fire deck is resurfaced flat with a finish compatible with MLS gaskets
• O-ring grooves machined into deck
• Multi angle performance valve job with radius cut for improved flow
• Set spring pressure, spring height, stem height, and valve recession
• New bonded Viton® valve stem seals installed and heads assembled
• O-ring wire installed, head painted and prepared for shipping
if you have 20mm heads, I personally wouldn’t worry about it. The threaded hole for the injector was moved and according to one respected engine machinist, the upwelling at that point is a contributing factor. And I would agree with that.
I ended up not going with the head supplier and machine shop I stated and went with UCF o-ringed heads. I sent my cores in and they said they were cracked beyond repair so no $500 core refund.
I installed the heads in April and just did my 5,200 mile oil change last week. Today I noticed a brown residue in my degas bottle and the smell test passed as DIESEL in my coolant. This means their “proprietary” sleeves on the 4 and 5 cups failed or some of the other cups cracked or there was a total head failure and one or both cracked. Either way I am going to get on the phone with them tomorrow morning and see what we are going to do about this or if their lifetime warranty is a sham and they are going to keep my “cracked” cores and send me back cracked heads and keep my $2300 and leave me with my engine on a stand. On top of this all I will have to buy new head gaskets and no telling what else no matter what. I’m not into bashing businesses but I sure hope they take care of this issue and don’t try to tell me the heat tabs are melted or my coolant return fittings are what caused this issue. The motor never got hot and ran just fine. Heat tabs melt at 250 degrees from what I gather. What say you Jack?
Thermal sensors can be of any temp. Cat had them on my motor, they should have spent the money towards QC.
The stupid thing about them is if you know where to buy them, someone could flip in new.
https://www.omega.com/en-us/sensors-...icating-labels
