Best wiper switch replacement options?
Old Jan 17, 2019 | 12:10 PM
Pickupmanx2's Avatar
Pickupmanx2
Well, after putting the switch in my 66 F100 (Shrek) back together 2x, it finally went kaput, single speed, 5 blades on back.
Looking for best way to keep stock ****, are there any good alternatives out there?
Thanks
Joe
Old Jan 17, 2019 | 02:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks
Joe
C3TZ-17A553-G .. Single Speed Wiper Switch - 5 terminals / Marked: C3TB-17A553-G (Motorcraft SW-722) / Obsolete
1963/66 F100/600 & N500/600.
This switch is very hard to find, no Ford dealer or obsolete parts vendor has any, none on ebay.
A member with a 1965 F250 Good Humor truck used a 1963/66 Econoline single speed switch w/5 terminals (C3UZ-17A553-C).
Another member tried it, couldn't get it to work. There's only one available, and knowing the source as I do (former parts guy pal), it's probably been sold.
You could convert to intermittent wipers, some members have done this. Type a thread asking how.
Old Jan 18, 2019 | 09:15 AM
James_Western_Canada's Avatar
Here is a write up on doing the intermittent wiper retrofit, but you need to start with a two speed wiper motor......
Installing a Factory Wiper Delay - FORDification.com
Old Jan 18, 2019 | 11:47 AM
6t6merc's Avatar
6t6merc
I suggest you consider swapping the entire system to two-speed, as I did. (I sold the one-speed switch and motor to a forum member.) If you do the swap to a two-speed with factory parts, you must use the two-speed system's crank arms as they are specific to that system and are slightly different lengths left and right. Once you have the two-speed system, the intermittent feature is a very easy and simple upgrade.
Eric
Old Jan 18, 2019 | 01:52 PM
cosmofennema's Avatar
cosmofennema
I would like to purchase the remains of your switch, sans ****.
Cosmo
Old Jan 18, 2019 | 02:33 PM
NumberDummy
1961/66 F100/1100: The single and two speed wiper transmission arms are the same. See 17540 in parts catalog pic (part numbers: C1TB-17540-A & C3TZ-17545-A).
Old Jan 19, 2019 | 12:06 PM
6t6merc's Avatar
6t6merc
Mine were different, which explains another problem...
Old Jan 21, 2019 | 04:01 PM
oldracerjones's Avatar
oldracerjones
2 Speed Motor
Eric
I'm assuming the two speed motor is if you have a low and high on your switch? If not, can you buy a two speed motor from another Ford model?
arvet19
Jul 19, 2017 08:26 AM
tonkaman3
32
Aug 22, 2016 08:38 PM
Shadowrider123
Dec 31, 2014 05:05 AM
ki0cn
Oct 20, 2009 05:32 PM
junkyardjeff
Apr 4, 2005 05:29 AM
