How to convert 57-60 to intermittent wipers
Several years ago I created a "how to" in the old gallery system that is now gone, so I decided to try to recreate the original "how to" here. I did the conversion using a wiper motor from a 1983 Ranger and a intermittent wiper switch from a 1979 F150.
Original wiper motor and Ranger motor
Original mounting bracket
linkage where it connects to the motor. Original, you have to modify the small cam arm.
I cut a plate from 16 gage steel
Drill holes in the new plate to match the Ranger motor. Cut holes in the original bracket big enough for a socket to fit.
welded it to the original bracket, at the top and through the original holes
Paint and bolt up to the motor
Modify the linkage cam arm to match the D profile. I drilled it out, added some weld to one side and filed it to match.
This is from a 1979 F150. 57-60 ***** work great
There are 6 wires on the black plug. 1) One black going to the red plug thus to the switch- hook up the power supply. 2) Another black going to the "box" - hook to the black wire from the motor. 3) Red going to the "box" - hook to the red motor wire 4) White going to the "box" - hook to the white motor wire 5) Blue going to the red plug thus to the switch - hook to the blue motor wire 6) Black with a white tracer going to the red plug thus to the switch - tis is for a washer if you have on
Mounted in the truck
Linkage hooked up
Works like a charm. Wipers park when you turn them off and you now have intermittent as well. Hope this helps if someone wants to convert.
1983/88 Ranger & 1984/88 Bronco II.
D1OZ-17A553-A .. Wiper Motor Switch-Use with Intermittent Wipers / Marked: D1OB-17A553-AA (Motorcraft SW-1010) / Obsolete ~ 77+ available NOS
1971 Torino/Montego; 1973/79 F100/350; 1978/79 Bronco.
Note: Intermittent wipers were optional, so not all these vehicles will have them.
sere0501
16
03-06-2016 09:23 AM
91dirtydiesel
307
09-13-2013 06:40 PM
