Australia Chapter Join Chapter , Leader: OPEN
F250 RN Scuttle
Old Sep 26, 2014 | 07:04 PM
Blue7.3's Avatar
Blue7.3
F250 RN Scuttle
Just thought someone would like to know how the scuttle is held on our 250's
The lower lip on the scuttle has a row of Christmas tree clips , there's six all together.<br/>These clips also hold a wiring loom on.
The top of the scuttle has #2 Phillip head screws along the screen edge.
Underside of the left side scuttle
Underside of the right scuttle
If you have to assess the wiper motor this will help in the removal of the scuttle .
Old Sep 27, 2014 | 04:52 PM
ChunderDownUnder's Avatar
ChunderDownUnder
thanks for the extra effort to help others out Blue. reps sent
Old Sep 27, 2014 | 06:23 PM
SSSimon's Avatar
SSSimon
Great post - this is particularly relevant if you want to fit electrical chokes around the wiper motor harness and/or wires as a cure for the intermittant stall when wipers are going.
Thanks for sharing!
Old Dec 13, 2014 | 05:13 PM
Blue7.3's Avatar
Blue7.3
Up-date on the scuttle removal and fit some ferrite chokes to all the wires on the wiper motor.
I'm getting this ready to fit a Elchin or BW CPS in the future.
Once you remove the scuttle you'll see the drivers side wiper mechanism .<br/><br/>It's a lot easier to remove the bonnet to get the scuttle off but can be done with it on .
left side wiper mechanism.
Wiper motor , left side
Pull the 10 mm bolt from the wiper motor , you don't have to remove the motor completely.
Remove the electrical plug, it's under the motor.
Cut the black tape off, this is a protective cover over the conduit.
Five wires , i put chokes on them all.
I cut the loom and lengthen the wires with the same colour wires.
I soldered the new wire on and covered with coloured heat shrink.
All the wires soldered on and fitted with heat shrink , now the ferrite chokes are fitted, i staggered them so they wouldn't be so bulky, also wrapped the wire around twice , just make sure you have enough wire left to join to the loom.<br/>I extended the loom about 400mm longer.
Wrap with good quality black electrical tape , then i'll cover with some water proof heat shrink.<br/><br/>
More to come later.
Old Dec 14, 2014 | 12:41 AM
Aussie BrianB's Avatar
Aussie BrianB
Excellent writeup Blue.
Where di you source the ferrites?
Old Dec 14, 2014 | 12:53 AM
Blue7.3's Avatar
Blue7.3
Brian B , i got them from Jaycar , they have a good selection , you should have them over there.
Old Dec 14, 2014 | 08:14 AM
Aussie BrianB
Thought that was probably the case, thanks.
Old Dec 15, 2014 | 01:46 AM
cyberdiamond's Avatar
cyberdiamond
Are they really that much better than the all the other ones.
I put a Delphi one on mine (factory one was still good, now its the spare) after hearing about the stalling issues with some of the BW ones.
I don't have AE so can't give any conclusive results for mine but happy to test the ones I have it if anyone has one and would like to know.
Old Dec 15, 2014 | 04:11 AM
Blue7.3's Avatar
Blue7.3
Yes i would be happy to see if the the Delphi will pass a CCT and see your Perdels read out, interesting to know i what numbers are on 3 and 8, maybe someone close to you has an AE that can do these test for you.
The Elchins has passed the CCT test and the perdels are all below 1.0, and with the ferrite chokes, there has been no interference with the wipers on intermittent or on, of course you have to fit one F/C on the CPS wiring.
You can see my perdels readings with the black CPS in another thread on this site.
Old Dec 17, 2014 | 02:55 PM
Blue7.3's Avatar
Blue7.3
Up-date:
Final part in fitting Ferrite Chokes.
Water proof heat shrink over the chokes
Soldered the wires together and covered them with heat shrink, this i the section I've lengthen.
Just getting ready to tape up .
All wrapped and reconnected.
This was the first attempt to tie the wiring down and found the the wiper mechanism came too close to it .
This is the final resting place for the wiper loom , it has plenty of clearance now , i also put a ferrite choke on the base of the wiring loom over all the wires.<br/><br/>Job done , now to fit some ferrite chokes to the CPS earth and feed wires.
ATG_Tuning
Dec 24, 2023 11:52 AM
Walston
Nov 3, 2018 02:04 PM
sere0501
16
Mar 6, 2016 09:23 AM
81ChopTop
Ford Truck Parts for Sale
Jan 21, 2013 07:52 PM
projectbad78
Apr 13, 2008 12:41 AM
