low fuel system pressure/injector control pressure too low issue
Old Oct 24, 2018 | 04:48 PM
Meanor24's Avatar
Meanor24
on my 2011 f550 it entered reduced power mode and didnt know why so i changed fuel fitlers and now it came up at low fuel pressure and codes came up the codes like P0305 and P2291 and P0087 any help would be really appreciated.
Old Oct 24, 2018 | 05:34 PM
Just Strokin's Avatar
Just Strokin
You can go here and download the ODBII for the MY2011 vehicles
https://www.motorcraftservice.com/freeresources/obd
I would start with checking to make sure the frame fuel filter canister is properly tightened. You may have an air leak and sucking air into the fuel system. Did yo uput clean fresh oil on the o-ring prior to screwing on the canister? Are you sure you tightened the canister to the stops touched?
P0305 – Cylinder 5 Misfire Detected - not low fuel pressure related - might be an injector going bad???
P2291 - Injector Control Pressure Too Low - Engine Cranking
P0087 - Fuel Rail/System Pressure - Too Low
Old Oct 24, 2018 | 05:59 PM
kper05's Avatar
kper05
How many miles on the filters prior to receiving the message and prior to changing due to the message?
Do you have any metal bits in the pleats of either the DFCM or engine mounted fuel filters you removed?
I'm thinking possible HPFP issues which can and will eventually cause injector issues. As suggested start with the simple things confirming the low pressure side (from DFCM) is correct and work your way forward. The high pressure side is (well) high pressure so if you aren't familiar with that system, you need to tow it to a diesel shop where they do work on these engines. If you can't rule out the HPFP, I wouldn't drive it. For example, if it is the HPFP and it hasn't come apart yet, you don't want to drive it and allow it to get to that point where it'll send metal shavings throughout the fuel system.
Brotherbillstruck
Oct 31, 2019 01:34 PM
parkland
General Diesel Discussion
May 16, 2018 07:58 AM
terrymargate
6.7L Power Stroke Diesel
May 8, 2018 11:32 PM
Gcapell
6.4L Power Stroke Diesel
Jul 4, 2012 09:29 AM
bobbyt89
Oct 11, 2011 09:07 AM
