HP fuel pump bites the dust
aslo need anti gel during the colder months to prevent fuel starvation and dry running fuel pump.
Also, you have responded in that thread I started about additives and I got trashed about mine. Still using it every tank and going strong with over 33k miles. Always appreciate your input with your time behind the wrenches.
I have a 17 6.7 and don’t use any additives and I’m not worried about it.My take on it is, if it’s gonna happen, its’s gonna happen.
These kits don't protect you from failures of the plungers and barrels that actually pump the fuel. Most fuel system failures that wipe the system out occur from here.
That kit and kits like them only protect you from metal shavings that come from the crankcase of the pump ( bearings/lifters/cam).
Isn't the whole reason for putting that on is to reroute it back to the tank so it goes there instead of through the injectors? I'm not being a wise guy, just trying to get more informed.
**"To be clear, this kit will not prevent the CP4 injection pump from failing, but what it will do is prevent failure of the rest of the fuel system in the event that it does fail. When the CP4 fails, metal particles from the fractured pump are forced to be sent throughout all secondary parts of the fuel system to include the fuel rails and injectors, most notably the injectors. These fragments will lodge themselves into the injectors and inevitably destroy them, and quite honestly, they're expensive. What the Disaster Prevention Kit does is reroute the direction of fuel that is responsible for lubricating the rotating assembly back through the factory fuel filters. Because of this, in the event the pump does fail, the contaminated fuel will be forced through both filters, which will capture these particles, inevitably saving your injectors."
**"The 6.7L Powerstroke uses a CP4 that has a high failure rate &, when it fails, sends metal debris through the high pressure fuel system. Prior to failing, there are no warning signs; it just happens. And it can happen at any time! When this happens, the ENTIRE high pressure fuel system needs to be replaced, costing upwards of $10,000!
The CP4 cannot be replaced with a more reliable CP3, so the only option is to reroute the fuel. This kit reroutes the fuel (and potential debris) back to the fuel tank so that all of the fuel entering AND leaving the CP4 goes through the fuel filters to catch any debris before heading off to the rest of the high pressure fuel system.
This kit is great insurance against a common disaster and can save you THOUSANDS!"
**6.7L Ford Powerstroke
CARB APPROVED
"Disaster Prevention Kit"
( CP4 Bypass Kit )
As many 6.7L Powerstroke owners have become painfully aware, the high pressure fuel pump (also known as a CP4 pump) has a design weakness. When the CP4 pump fails, it will shed tiny particles of metal throughout the entire high pressure fuel system. The only cure in this case is to replace everything in the high pressure fuel system - CP4 pump, fuel injectors, injection lines, fuel rails, etc. We hear from our customers that the total cost of this repair with labor can be in the $9,000 range.
THE CURE
The CP4 disaster prevention kit cannot prevent the CP4 pump from failing. What it does do is prevent the contamination from the failure from entering the high pressure fuel system.
HOW IT WORKS
The CP4 pump is internally lubricated by diesel fuel from the tank. After lubricating the crankcase area of the CP4 pump, fuel enters the high pressure pumping chambers and exits under pressure to the fuel rails and fuel injectors. The weakness of the CP4 pump lies in the crankcase area where a set of roller lifters ride on a camshaft. When the failure event occurs the lubricating fuel becomes contaminated immediately. Our bypass kit mounts to the CP4 pump and changes the routing of the fuel flow so that lubricating fuel from the crankcase is directed back to the fuel tank to be filtered before going through the fuel system again. Thus all fuel entering the pumping elements of the CP4 pump and leaving for the injectors is always routed through both of the vehicle's fuel filters to eliminate any chance of contamination from a high pressure pump failure.
This one-time investment of $359 could easily save over $9,000 in repairs and weeks of downtime. It is an absolute must for any 6.7L Powerstroke owner!
CARB COMPLAINT
Every kit now comes with a CARB compliant decal making this modification 100% street legal in all 50 States for 2011 - 2016 model year trucks. The kit also fits 2017 year trucks with CARB compliance pending. According to our understanding, Ford's position is that any modification that is CARB compliant will not void the manufacturer's warranty.
CARB EO# D-756-1
MADE IN THE USA
So this is all false and your injectors and lines will still be wasted?? I'm looking for someone who has more knowledge than me about this fuel system and modern diesel engines in general, which is used by other GM also I believe. It would be nice to be able to retro fit a CP3 in our trucks as from what I've read, they are more durable. Just looking for answers, gentlemen. Thanks.
CARB APPROVED
( CP4 Bypass Kit )
THE CURE
HOW IT WORKS
CARB COMPLAINT
CARB EO# D-756-1
MADE IN THE USA
So the kit will prevent fuel system failure from metal being sent into the system via the lubricating fuel. It will not protect your system from the plungers and barrels failing.
If they are right, and the pump's crankcase is the start of the problem, then within a very few revolutions the top will also be trashed and you won't be able to tell where it started. On the other hand, if I understand the circulation of the fuel, if the fault starts in the top, this is downstream of the bottom end and the bottom will still look good. That means that for trucks in the garage with a trashed CP4, most of them would have a good bottom end but a trashed top end. If accuratediesel is right, most failed CP4 pumps will have both top and bottom trashed. Which is it? In the case of the OP, which was it?
