will '57 grill/headlight housing fit '60
Old Sep 22, 2003 | 12:24 PM
medicop's Avatar
medicop
i am still in the process of getting all the pics together for the gallery. does any one know if the headlight housing from a '57 will fit the front of a '60 f-100. like i said before i want to french in the headlight housing and that large dogbone will be a pain to wrestle with. i figured the smaller one piece from the '57 will be easier to handle. then put maybe a late '40s early '50s merc. or even early '50 f-1 grill teeth in the space between th lights. if any one can help with this problem i would appreciate it.
thanks
chuck
Old Sep 22, 2003 | 10:19 PM
Kenny's Avatar
Kenny
Front ends are indeed interchangeable, however headlight buckets for each year of '57-'60 are different.
In other words....
You can put 1958 headlight buckets on a 1959, but it won't work if you're planning on keeping the '59 grille.
Not exactly sure I understand what it is you are trying to do, but I hope this helps to answer your question.
Old Sep 23, 2003 | 10:56 AM
medicop's Avatar
medicop
thank you for the help. what i want tjo do is take just the headlight housing from the '57 and french it into the area of the old headlight. i am going to fab a grill for the middle.
thanks again
chuck
SuperDuty93
Dec 24, 2013 06:41 AM
Truckie561
Nov 15, 2012 05:13 AM
fast58
Mar 22, 2012 01:01 PM
medicop
May 9, 2005 10:48 PM
