Headlight housing?
Old Dec 6, 2013 | 06:19 PM
SuperDuty93's Avatar
SuperDuty93
Headlight housing?
Will all the 57-60 headlight housings be the same? I have a 59 f100 and need a set wanted to be sure they are all interchangeable.
Im also looking for two headlight bezels for a 59 if anyone has one.
Old Dec 6, 2013 | 11:25 PM
Maltman's Avatar
Maltman
not sure on housings...where has Numberdummy been?
bezels are year specific I am pretty sure, try eBay. make sure seller has correct year on listing. or search the for sale ads on here...mine were rusted so I sanded and painted a silver with a flake in it, think it turned out ok. just another option if you come across rusted bezels. flash makes paint look splotchy...but it isnt
Old Dec 6, 2013 | 11:26 PM
Maltman's Avatar
Maltman
here is pic...
Old Dec 7, 2013 | 12:23 PM
F250racer's Avatar
F250racer
The actual mounting housings are all the same as far as I know. The bezels are different. I think 57-59 might be the same(or at-least pretty close), but the '60s are shaped differently.
Old Dec 7, 2013 | 02:40 PM
oldebrush's Avatar
oldebrush
Headlight housing?
They are all different. 57 being single lamp headlights, 58 is dual, 59 and 60 may be similar but you need to watch the space between the lamps on those. The 58 is closer together than the 59/60.
As far as the 58,59 and 60 lamp buckets, these might be interchangeable. The bright metal retainer rings should be also.
Hope this helps some.
Aloha, Tony.
Old Dec 24, 2013 | 06:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Headlamp buckets and doors: 1958 is one year only, as is 1959 and 1960.
jgarrison31
Feb 24, 2019 01:53 PM
FordTruckNoob
Minnesota Chapter
Apr 22, 2011 11:25 PM
copasspupil
Dec 7, 2010 09:23 AM
STEVE1103
Jan 28, 2006 10:06 PM
