brake light switch adjustment
Old Jun 23, 2018 | 08:01 PM
columbia1spring's Avatar
columbia1spring
74 f100 automatic
I bought a new brake light switch and was thinking a few minutes to swap it out.
Theres a metal retainer on it and i think i dont wanna break it even thow the new switch didnt come with one...
any secrets on removing it?
Old Jun 24, 2018 | 10:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by columbia1spring
74 F100: I bought a new brake light switch and was thinking a few minutes to swap it out.
There's a metal retainer on it and I think I don't wanna break it even though the new switch didn't come with one.
Retainer sold separately, does not come with the switch.
The retainer (13A629 in pic) has prongs on it that retain it to the pedal. The prongs snap off, the retainer either dangles or falls off the pedal taking the switch (13480) along with it.
C8TZ-13A629-A .. Brake Lamp Switch Retainer / Obsolete ~ 10 available NOS .. It may be reproduced.
1968/77 F100/350 // 1969/74 E100/300 // 1978 F100/350 before serial number CC0,001.
See lower left in pic:
Old Jun 24, 2018 | 04:14 PM
columbia1spring
The problem I'm having is that when your foot is off the brake it drops ever so slightly, 1/8 of an inch maybe, but just enough for the brake lights to stay on.<br />i bought a new switch and it came with 2 nuts instead of the original retainer. I just have to decide what set up to use.<img src="https://cimg8.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/1200x1600/img_0297_e3415fd7447541a3026495bc60eeed89fb94a486. jpg"/>
Old Jun 24, 2018 | 05:52 PM
NumberDummy
The retainer is threaded, how are you going to install the switch and then adjust it without using the retainer?
Old Jun 24, 2018 | 06:23 PM
columbia1spring
i don't understand your question. Don't you see in the picture that the new switches come with 2 nuts to lock against each other when tightened. You don't need the retainer if
Using the new mounting system. So my original concern, should I use the retainer or the the double nut system, what would be more dependable?
Old Jun 24, 2018 | 06:48 PM
flatbedfordguy's Avatar
flatbedfordguy
You're way over thinking this....use the same mounting hardware that you took off the old switch if that makes you more comfortable, if not, use the new mounting hardware, either will work just fine.
The more prudent point is being overlooked.... do your brake lights work after the fix?
Old Jun 24, 2018 | 06:57 PM
NumberDummy
The hole in the pedal is not threaded, the retainer is. So how can you thread the switch onto the pedal since it has no threads?
Old Jun 25, 2018 | 10:05 AM
columbia1spring
This was such a simple fix, I just like things done original and correct.
for the record, I unscrewed the brake light switch and went to screw the new one in.
The threads on the original retainer didn't match the overseas replacement switch so I was forced to use the 2 nut system .
Overall, its an under 5 minute job!
Old Jun 25, 2018 | 01:11 PM
flatbedfordguy
This was such a simple fix, I just like things done original and correct!
I understand, I am a stickler for that sort of stuff as well. Glad you got it fixed!
jeffrey2
Feb 2, 2021 08:01 AM
Coorslight3322
Apr 15, 2016 11:19 PM
daveengelson
18
Mar 6, 2015 05:55 AM
Marnus Steyn
May 18, 2004 01:54 AM
leonharu
Jun 26, 2002 10:03 PM
