Neutral safety switch 74 f100
Old Jun 22, 2018 | 05:35 PM
columbia1spring's Avatar
columbia1spring
I am having issues with the neutral safety switch. First I needed a slight wiggle on the gear selector, then only started in reverse, now only in drive!
i have a new one with other items from lmc, but I want to take it to a show this week end. If it totally craps out does anyone know what wires to splice together to by pass it?
There are 4 wires pictured.
The switch is inside the truck
Old Jun 24, 2018 | 11:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The NSS selector lever is either broken, or is missing.
i have a new switch with other items from lmc, but I want to take it to a show this week end. If it totally craps out does anyone know what wires to splice together to by pass it?
The switch is located towards the bottom of the steering column.
D0TZ-7B097-B (replaced C5TZ-7B097-A & D0TZ-7B097-A) .. NSS Selector Lever / Obsolete
Applications: 1965/77 F100/350.
This lever clips onto the shift tube thru a hole in the steering column shroud, has a knife blade end that pokes into the NSS
When the knife blade end snaps off (very common), the truck can be started in any gear.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 789 = 800-476-9653.
C7TZ-7A247-A .. NSS (Motorcraft SW-600) / Obsolete ~ Available NOS & from auto parts stores, so you don't have to buy it from LMC in KS and then pay shipping charges.
Applications: 1967/77 F100/350.
Old Jun 26, 2018 | 11:27 PM
Tugzilla's Avatar
Tugzilla
Columbia1spring
I believe the Red w Blue stripe wires are for the Ignition Switch and the Starter Motor Relay. The switch when working correctly completes that circuit when in Park and Neutral allowing the engine to start when the key is turned. Usually, when the ability to start "changes gears" it's because the adjustment of the switch on the column has changed (it has a certain amount of adjustment on the column) or the switch is wearing and going bad. The Black w Red stripe wires are for the reverse light circuit (12v power and reverse light connection) and is completed when the switch is in the reverse position (adjusted and working correctly). To bypass the switch, you should be able to tie together the two Red w Blue stripe wires. However, this will allow the truck to start in every gear whenever the key is turned to start. Both Jeff's Bronco Graveyard and Dennis Carpenter sell that switch for about 50 bucks. Hope this helps.
Mike
Old Jun 27, 2018 | 07:31 AM
columbia1spring
As I feared I was at a truck show and couldn't get it started. An old timer came over with a 6 inch wire, unplugged the
nss from the harness and used the wire as a jumper with the red wires! Started right up. The new switch will be delivered
This week.
Thanks for that great reply
Old Jun 27, 2018 | 01:47 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Some NSS info. https://www.ford-trucks.com/forums/1...l#post14696864
JBMorrey
Feb 5, 2018 10:37 AM
Smirks90
Dec 14, 2014 07:57 PM
Steven Gatley Sr
Electrical Systems/Wiring
Jun 8, 2014 09:12 PM
hairyboxnoogle
Sep 19, 2011 07:44 PM
Sycostang67
Apr 17, 2009 01:15 PM
