B/U lights...wheres the switch?
Old Apr 17, 2009 | 01:06 AM
Sycostang67's Avatar
Sycostang67
I cant get the reverse lights to work on my 74. I changed the bulbs, cleaned the sockets, and checked the fuse. I didn't see any wires on the transmission. Is my switch gone or am I looking in the wrong place?
Old Apr 17, 2009 | 02:04 AM
79f2506.6L's Avatar
79f2506.6L
look on your colunm
Old Apr 17, 2009 | 07:19 AM
tlolesen's Avatar
tlolesen
If its an automatic, in my 75 F-100 it is about 5 inches off the floorboard on the back side of the column. There is a pin that sticks out and moves the switch when you move the shift lever. This is also your neutral safety switch. When I got this truck the pin was missing and I just removed the switch and put a toggle on the dash for back-up lights when I need them. They work great if you need to see something even if your not backing up. My neutral safety switch is also bypassed because the switch went bad and I usually start my truck in park like normal people.
Old Apr 17, 2009 | 07:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is a pin NSS SELECTOR LEVER that sticks out and moves the switch when you move the shift lever. This is also your neutral safety switch. When I got this truck the pin was missing and I just removed the switch and put a toggle on the dash for back-up lights when I need them. They work great if you need to see something even if your not backing up. My neutral safety switch is also bypassed because the switch went bad and I usually start my truck in park like normal people.
DOTZ7B097B .. NSS-Neutral Safety Switch Selector Lever
Fits: 1965/77 F100/350.
This lever is Y shaped, snaps to the shift tube thru a hole in the mast jacket.
One of two things happens to it: It's spring steel, so when it loses tensile strength, it falls off, or...
More common, the tip snaps off.
Ford just obsoleted this part, however...
MCSPADDEN FORD in Globe AZ has ONE.
BRADLEY FORD in Lake Havasu AZ has ONE.
DON SANDERSON FORD in Glendale AZ has TWO = 623-842-8762.
PARTS INTERNATIONAL in Farmers Branch TX has 18 = 888-727-0418
GREEN SALES CO. in Cincinnati OH has 12 = 800-543-4959.
There's at least 150 more at other Ford dealers and other obsolete parts vendors.
C7TZ7A247A .. NSS-Neutral Safety Switch (Motorcraft SW600)
Fits: 1967/77 F100/350 / Still available from Ford...but the price is sky high.
Also available from NAPA.
1953/60: The NSS is located on the steering column UNDER the hood.
1961/77: The NSS is located on the steering column inside the cab.
1978 and later: The NSS is located on the manual control lever of the transmission.
Old Apr 17, 2009 | 01:15 PM
Sycostang67
The column huh, I'll check it out, thanks. If I have to replace it it will be nice not laying under the truck to do it.
