bench bleed question
Old Mar 3, 2018 | 05:25 PM
GoldCo's Avatar
GoldCo
New MC from Speedway…
1) use nothing on fitting threads? How tight?
2) dumb question, but once bled in vice, when I remove plastic nozzles isn’t the fluid going to just pour out of holes as I try to thread fittings back in?
Old Mar 3, 2018 | 07:05 PM
moejr's Avatar
moejr
finger tight should work fine ..... after bench bleeding you can plug the ports to stop the fluid from leaking out while you get ready to install your lines.
Old Mar 3, 2018 | 07:36 PM
Mixer man's Avatar
Mixer man
As long as you don't move the spool you'll only get a few drops (Pascal's Law), but put a plug in it ASAP.
Old Mar 5, 2018 | 02:41 PM
GoldCo's Avatar
GoldCo
i'll be running a residual valve for the rear drums and a proportioning valve: what is the ideal order of install for these items inline? prop valve followed by residual, or residual valve ahead of the prop valve?
firewall mounted boosted MC, disc/drum setup
thanks in advance.
Old Mar 5, 2018 | 03:15 PM
moejr's Avatar
moejr
no need for residual valves with a firewall mounted master as far as I know. I have a firewall mount & didn't use them.
Old Mar 5, 2018 | 05:25 PM
avf100's Avatar
avf100
Yep, no need for a residual valve with a firewall mount master. A residual valve is only needed
when the master is down on the frame below the wheel cylinders and calipers
Old Mar 6, 2018 | 12:18 PM
GoldCo's Avatar
GoldCo
hmmm, well i already own it now, based on the info at Speedway Motors:
"Drum brakes will always require a 10psi residual valve regardless of the master cylinder mounting position."
any pix of your MC / prop valve mounting setups? i've seen lots of curly Q brake lines — need to figure out my layout (bending / flaring my own lines).
thanks.
Old Mar 6, 2018 | 01:28 PM
avf100's Avatar
avf100
Didn't know that about needing a residual valve with rear drum brakes, but I'm no expert.
Old Mar 6, 2018 | 01:43 PM
avf100's Avatar
avf100
Here is a couple pics of mine. I have 4 wheel disc. I tried using the copper/nickel tubing and flaring them myself, but that didn't go to well. Ended up having 4 of the flares leaking. Probably from my cheap azz flaring tool. So I ended up tearing it all out. I bought a brake line kit from speedway that has preflared lines in different lengths. The hard part for me,was figuring what way to route the lines, so I ended up with the right length. So I wouldn't have to cut & flare.
Old Mar 6, 2018 | 05:35 PM
GoldCo's Avatar
GoldCo
Thanks, that is helpful to see...
Yeah, I'm a bit nervous about my flares — guess we'll find out eventually!
hello113
Nov 4, 2017 08:47 PM
alchemist1
13
Dec 9, 2012 02:06 PM
NC2X4
27
Sep 15, 2010 10:54 PM
hugofc
Jan 5, 2001 01:08 PM
