Sponsored by: Real Truck
Low speed, Hard to start
Old Dec 11, 2017 | 07:57 PM
Kbennettv10250's Avatar
Kbennettv10250
1999 F250 V10 Hard to start, low engine power, new parts installed all injectors, all spark plugs, all coil packs, fuel pump, need help
Old Dec 11, 2017 | 08:57 PM
Djosbun's Avatar
Djosbun
What do you mean by “hard to start”? Do you mean the engine turns over slowly and takes forever to finally run (as in a weak battery), or does it crank beautifully and just takes too long to fire itself and run?
If its the latter, check the fuel pressure at the rail by the injectors. Fuel pump failures are more common than other issues. If fuel pressure is good, how do the plugs look? Install new plugs and drive the thing, then pull the plugs and read them. Check for deposits or if the insulator is too dark (or too light).
Poor compression can cause this, but I’d start at a fuel supply issue here.
— Dave
Old Dec 11, 2017 | 09:28 PM
Kbennettv10250
It turns over and over and finally it starts but it has a miss and I press the pedal, but it has hardly any power to move.
BaldExpDvr
Jan 6, 2018 02:13 PM
therigwelder
Nov 14, 2014 04:16 PM
Stroked99
Jul 17, 2012 01:33 PM
lg1
15
Nov 28, 2005 06:57 PM
moritz1024
1978 - 1996 Big Bronco
13
May 31, 2004 09:49 PM
