bed sealer at front of bed
Old Sep 15, 2017 | 06:47 AM
jackstar's Avatar
jackstar
My 77 F250 CS has a pretty intact bed and I plan on spraying a color coded bed liner in it this month. However, I noticed that there is what looks like heavy duty factory seam sealer still on both sides of the bed as it comes down to join the flat part of the bed. Is that still available for use on the bed thereby sealing it from water intrusion and then spraying the bed? If it is, where can I get it? Thanks.
Jack
Old Sep 15, 2017 | 08:40 AM
lafermedavid's Avatar
lafermedavid
bed sealer
eastwood or any paint supplier,or speed shop
Old Sep 15, 2017 | 08:55 AM
HIO Silver's Avatar
HIO Silver
3M seam sealer or 3M window weld. Get a cartridge for ease of application.
Old Sep 15, 2017 | 09:02 AM
gittinwidit's Avatar
gittinwidit
I think the issue in that location is that the bed is made to drain in the front. If you load it up with sealer, just park down hill or it becomes a bath tub pretty quick.
I always drill 3/4" holes in the lower grooves in the 4 corners to remedy this. And seal the front for it will rust out underneath with mentioned sealers. I use 3M. I made my applicator much cheaper than 3M's price to use in a regular caulk gun. I'd only buy the applicator if you do it often.
Old Sep 15, 2017 | 09:47 AM
HoustonDave's Avatar
HoustonDave
I used to use my bed as a rain gauge. Sometimes folks run the seam filler along the fron of the bed to seal it; this will trap water. If you use a relatively small (1/4" bit, you can put about 4 equally spaced holes along that front seam and it will be inconspicuous and drain efficiently. I just came through over 40" of rain from Harvey and my truck drained completely very soon after the rain stopped.
Old Sep 15, 2017 | 10:02 AM
HIO Silver's Avatar
HIO Silver
I believe the OP is referring to the sides of the bed where "it meets the flat part" - the section that is not ribbed fore and aft of the wheel wells.
Old Sep 15, 2017 | 10:26 AM
jackstar's Avatar
jackstar
Right. The part I am referring to is the flat ribbed portion that butts up against the back wall of the bed. There's a 1/8 to 1/4 inch gap that I want to wire brush, Ospho, seal and then paint. I understand the dangers of sealing a bed.
wyckedcombo17
Mar 9, 2011 06:06 PM
Big Ruth
Apr 4, 2010 03:51 AM
tealboy1
May 26, 2002 08:16 PM
Oaf
Aftermarket Products
Jun 7, 2001 11:23 AM
