Additional Fuel Filters System In-Line
Old Sep 14, 2017 | 10:38 PM
WK15's Avatar
WK15
I had a DIESELSITE 2011-2016 Ford 6.7L Fuel Filter / Water Separator on my 2012.
I took it off before trading it in. I was told that this system will not work on the new 2017s. Now I have a system that I can't use. Dang it!!!!!
Does anyone make something like this for the 2017s?
- Airdog has nothing listed for 2017s
- FASS has nothing listed for 2017s
- DieselSite states: the older 2011-2016 Ford 6.7L Fuel Filter / Water Separator System "WILL NOT" be able to be used on the system on the 2017. The fuel pump has been moved from on the frame to inside the tank, and because our system needs to be between the tank and the pump, the system will no longer function properly. We currently have no system/solution in development for the new trucks.
Thank you for the help.
Old Sep 15, 2017 | 08:43 AM
Crashman927's Avatar
Crashman927
That is a bummer.
Just wondering if it will not fit on the 17s are willing to sell it? Just sold my 7.3. I don't have my 6.7 truck yet but I'm waiting for the dealer in Ohio to open so I can talk to them about hopefully my new Truck. So this might be a good addition for it.
Old Sep 15, 2017 | 10:22 AM
Khena's Avatar
Khena
Call Baldwin Tech support and find what filter will work best under the OEM pressure and flow. Then splice your own in using a Baldwin filter base such as a FB1310. If you don't mind doing some research and a little fabrication, it should work great and save you a lot of money. That's assuming they have one that will work with the application.
800-822-5394
rcorcich
6.7L Power Stroke Diesel
Apr 1, 2013 06:39 PM
7.3stroker95
Jun 29, 2012 10:14 PM
koabob
Jun 8, 2009 06:11 PM
ts_stroker
Feb 1, 2008 10:07 AM
phatdually1
May 22, 2007 08:56 PM
