Signal lights
Old Sep 5, 2017 | 02:05 PM
marine dad's Avatar
marine dad
Signal lights
Hi. I've had my black 62 named Ol Blue lol for 1 year. The signals don't work. I noticed 3 or 4 fuses under the ebrake. Before I screw something up, what may be the problem. The turn signal lever doesn't look stock. It has a red buttom to pull for emergency lights which don't work either. Brake lights and park lights work fine. Any ideas? Are any of those fuses for signals?
Old Sep 6, 2017 | 12:37 AM
shadyside1983's Avatar
shadyside1983
I have a circuit diagram here for the 1965 F series which suggests the turn signal circuit was protected by a fuse mounted in a fuse panel on the firewall near the e-brake. An
orange wire with a yellow tracer goes to the flasher where the power for the brake lights branches off to the stoplight switch. Then the power leads the stock turn signal switch in the steering column. Truck as built apparently did not have inline fuses. As you do not have a stock turn signal switch let the games and detective work begin.
Old Sep 6, 2017 | 12:40 AM
shadyside1983
In addition to post 2 above, if you have power to the brake lights it would suggest power is getting as far as the input side of the flasher.
Old Sep 8, 2017 | 10:52 AM
Old Coyote's Avatar
Old Coyote
My advice is ditch the non-stock switch and replace with stock. They're not expensive and it's a pretty simple system.
Old Sep 8, 2017 | 01:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/66 is not the same as 1961/64.
1961/64: The fuse box attaches to the headlamp switch.
1961/62 F100/250 2WD's use the same T/S switch as 1960/61 Falcon/Comet (C0DZ-13341-A). The metal T/S canceling cam (C0DF-13304-A) is a separate part.
michael69
Jul 15, 2019 10:37 AM
Redneckrucker16
Jul 22, 2014 12:05 PM
dinoant
Escape & Escape Hybrid
Jan 9, 2013 08:14 AM
vettman
Mar 5, 2011 12:34 PM
cjben
Electrical Systems/Wiring
Sep 10, 2003 05:16 PM
