can anyone tell me what is causing this noise on my car
Old Jul 30, 2017 | 09:16 AM
andrew871's Avatar
andrew871
can anyone tell me what is causing this rattling ticking noise on my 2005 ford expedition here is a link to my expedition making that sound......
any help would be appreciated thanks
Old Jul 30, 2017 | 09:19 AM
alloro's Avatar
alloro
It sounds like the belt tensioner is hitting it's wear indicator stops. If so it's time to replace the serpentine belt because it is stretched to it's maximum.
Old Jul 30, 2017 | 05:15 PM
andrew871's Avatar
andrew871
Ok I went and bought a new serpetine belt and put it on and the noise is still there so its not the belt what would be your second guess of what is causing the rattle noise
Old Jul 30, 2017 | 06:28 PM
Hamfisted's Avatar
Hamfisted
How many miles are on the Expy? It looks like it's running a little rough. Could it be timing chain slap ?
-Mike
Old Jul 30, 2017 | 10:02 PM
andrew871's Avatar
andrew871
It has 220k miles on it
Old Jul 31, 2017 | 08:07 AM
alloro's Avatar
alloro
Did you first check to see if the wear indicator on the tensioner was all the way over? If it wasn't then there was no need to replace the belt. Next thing to try is to remove the belt and run the engine for 1/2 a minute to see if the noise goes away. If it does the noise is belt related, if it doesn't then it's obviously something else.
Old Jul 31, 2017 | 10:30 AM
lincolnshibuya's Avatar
lincolnshibuya
do you get a whine when accelerating?
you could try remove the serpentine belt and run the pulleys, if they freewheel then it's time for replacement (there should be some resistance when trying to spin the pulleys)
at the same time you can start the car and listen for the noise, if the noise is still there then it's not the pulleys but something inside the engine (could be timing chain related)
https://www.facebook.com/diyLincolnNavigator/
Old Aug 1, 2017 | 09:31 PM
Brett_N's Avatar
Brett_N
Oh welcome to my world.
Was the video shot with the engine warmed up? Or was that right from turn of the key?
Mine sounded like that when I first turned it on, then it would go away. A bottle of Lucas Oil Stabilizer later, no more rattling.
If it "squeals" when you hit the gas (usually around 2K RPM) it's probably an idler, alternator, or AC compressor bearing. I replaced all my idlers and tensioner, and am now in the middle of the stupid AC bearing.
cammer32v
Feb 25, 2009 05:01 PM
chimchim
Oct 20, 2004 03:09 PM
fpbIII
1983 - 2012 Ranger & B-Series
Oct 4, 2004 06:53 PM
surfer8400
Mar 19, 2004 09:56 AM
