anyone ever modified the BPD Oil cooler relocation kit
Old Jun 11, 2017 | 11:16 PM
BLADE35's Avatar
BLADE35
I. Am thinking about doing this type setup
BPD relocate kit with 100% filtration spliced in
My thoughts are getting a filter setup to flow enough to cool oil even if it a twin filter setup with a tee
​​​​​​​What else do you guys see being an issue??
Old Jun 12, 2017 | 10:00 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Oil temp issues Benny? Or just in the mood for a project?
Old Jun 12, 2017 | 01:58 PM
BLADE35's Avatar
BLADE35
Oil cooler plugged up again I'm sick of gutting the top half the engine
​​​​​​​I just want to change filters
Old Jun 12, 2017 | 02:28 PM
npccpartsman's Avatar
npccpartsman
Do you mean to not use the BPD cooler?
Old Jun 12, 2017 | 03:13 PM
Splash67's Avatar
Splash67
Space is always an issue with our trucks.
I'm not sure that I'd put the filter inline with the cooler. Just add an auxiliary filter from a company like Sinister or something.
Old Jun 12, 2017 | 07:33 PM
shiftkx's Avatar
shiftkx
i have a bpd kit, i mounted it in the center of the grill and made my own hoses
Old Jun 12, 2017 | 08:14 PM
Rusty Axlerod
So counting the origonal, this is the third oil cooler for you? I know laying across the front of your truck is gonna be hell on your back but at least you know exactly what to do now. Doesn't all the oil going to the cooler go through the the filter on BPD Kit? I thought the block adapter replaces the factory filter and replaces it with that big honkin' spin on filter.
Old Jun 12, 2017 | 08:33 PM
Splash67's Avatar
Splash67
They sell a kit that reuses the factory oil filter.
Old Jun 13, 2017 | 09:33 AM
BLADE35's Avatar
BLADE35
This is oil cooler 4 it's my bad but last one I blew the flush
My intention is to filter coolant @100% prior to OEM cooler that's relocated
Old Jun 13, 2017 | 10:16 AM
Per4mance's Avatar
Per4mance
I'd look into the IPR then if that's what you want to do. The cooler isn't mounted under the oil filter and it looks like it would take a 1/2 hour to change out if you need to.
Old Jun 13, 2017 | 05:42 PM
bismic's Avatar
bismic
Benny - sorry to hear this!!
I wonder if it isn't the oil cooler bypass valve? I don't think it is common, but they do occasionally fail (open).
Old Jun 13, 2017 | 06:01 PM
jsm180's Avatar
jsm180
Do you know what's clogging the cooler, rust, sand, gel or just crud?
Old Jun 13, 2017 | 08:56 PM
BLADE35's Avatar
BLADE35
Flakes of something clogging it
Last year when I did oil cooler I pulled it out and once I saw the flakes I new the vc9 flush I did was a bust
I tried soaking the flakes in simple green and I think lacquer thinner just to see if I could break them down but those didn't touch it
Old Jun 13, 2017 | 09:03 PM
BLADE35's Avatar
BLADE35
The flakes look like gold color when held to light
Really thin almost transparent
Kinda a dull red color if your not holding the flakes to a light
Idk what it is honestly best I can figure is the original gold coolant protection layer hardened and came out 6 years after the switch to ELC
​​​​​​​purely a guess
Old Jun 13, 2017 | 09:33 PM
TooManyToys.'s Avatar
TooManyToys.
VC9 won't clear that very well. Need to go alkaline.
