Bluetooth skipping/pausing/unpausin when streaming music or youtube from phone
Old May 21, 2017 | 06:05 AM
Bohen's Avatar
Bohen
The best way to describe this is as if it was pausing and unpausing but only happens when I play music or play videos from my phone with Bluetooth but when I'm on a phone call or playing music off of the SD card , USB drive or CD player it's fine no issues. I have done a factor reset on my phone and the nav/head unit , I also unplugged both batteries and for the hell of it removed the fuse and nothing worked .... Help this is driving me crazy Thanks Oh my truck is a 2015 f350 Lariat with the Sony navigation system. P.S. it's not my phones Bluetooth because the Bluetooth works GREAT on my other devices at home . Thanks again
Old May 21, 2017 | 06:49 AM
Just Strokin's Avatar
Just Strokin
Have you considered the streaming of the songs or video is exceeding the band width needed via bluetooth? Try using a USB cable to connect phone to truck and see if the same results.
Old May 22, 2017 | 05:55 AM
Bohen's Avatar
Bohen
I will try connecting it as you say but it was never an issue until just one day it started having this issue thank you for your advice .
Old May 26, 2017 | 09:06 AM
k7lvo's Avatar
k7lvo
If you're still having the issue, you might consider power-cycling the unit. Find the keep-alive fuse and remove it for 30 seconds or so. (On my '14 I think it's 31 in the passenger kick panel fuse block. If you don't have to reset the time, memory stations, and Bluetooth afterwards, you didn't find the right fuse.)
Old May 27, 2017 | 06:03 AM
Bohen's Avatar
Bohen
removing the fuse did not do anything
Old May 28, 2017 | 07:51 AM
Deuce40s's Avatar
Deuce40s
Is your music stored on your phone or are you streaming? Occasionally if I'm streaming, it'll skip a bunch. That's a bandwidth issue.
Old Jun 7, 2017 | 07:30 PM
Bohen's Avatar
Bohen
Took it to the dealer on Saturday they had the truck for three hours so that there were no codes so apparently there's no issues get the truck back no change still skipping all that crap this sucks
conradg_7
Nov 4, 2015 10:21 PM
1996f3507.3
Apr 16, 2010 07:28 AM
ncguy23
May 29, 2007 04:58 PM
Monarchfootbal77
Oct 30, 2006 09:35 AM
