96 F150 Audio Help
Old Oct 29, 2006 | 09:38 PM
Monarchfootbal77's Avatar
Monarchfootbal77
96 F150 Audio Help
The other day I was taking out my broken CD player to reinstall the factory cassette player that I know works. I got it hooked up, but when I turned the ignition on, it didn't work. The actual buttons lit up, but nothing on the "screen" and no sound. I tried to install the CD player again, but nothing. Now I know for a fact that the factory one is good. I checked the fuse panel and that fuse is good. Can anybody help me find the problem? All I have to listen to is exhaust now!
Old Oct 29, 2006 | 11:09 PM
quicklook2's Avatar
quicklook2
bet you did not disconnect battery.
go under hood to the power dist. box and check fuse 1 a 20 amp fuse that supplies audio power.
Old Oct 30, 2006 | 08:01 AM
Gunman's Avatar
Gunman
The power that lights the buttons is a sperate circuit from the one that powers the radio/cd unit. Although it is on the same plug. Do as quicklook2 says and see if you have a fuse blown for that.
Old Oct 30, 2006 | 08:08 AM
Monarchfootbal77
Thank You guys I just checked and the fuse is blown.. After school I'll pick a few up and get it fixed..
Old Oct 30, 2006 | 08:11 AM
Gunman's Avatar
Gunman
Glad to help
Old Oct 30, 2006 | 09:34 AM
quicklook2's Avatar
quicklook2
it does not help that in the power dist. box it only has numbers and not what the fuses/breakers are for.
glad it was just a fuse.
Old Oct 30, 2006 | 09:35 AM
Gunman's Avatar
Gunman
You know how engineers are!
