460 transmission not shure what to use
Old Apr 28, 2017 | 06:08 PM
Molson003's Avatar
Molson003
I have a 1978 f250 that had a six cylinder in it and I am puting a 460 in it but I don't know what to get for a transmission the six cylinder had a four speed manual but I'm not shure what I need. I still want a manual but not shure on the make.
Old Apr 28, 2017 | 07:59 PM
SlikWillie's Avatar
SlikWillie
First, welcome to FTE. Second, we all here LOVE pictures. Feel free to show off your dentside truck no matter how pretty or ugly she may be. And third, look for a ZF5 from a '87 to '97 F250/350/450. Make sure it was bolted to a 460, although I have heard that the diesel models will work too. There are plenty of threads here that go into detail of the swap. If a ZF5 is out of your budget, look for an NP435 or T18. Both are granny 4 speeds, the ZF5 is considered a granny 4 speed with OD. Hope this helps ya.
Old Apr 28, 2017 | 08:37 PM
Molson003's Avatar
Molson003
Does it matter if it is a 4x4 ? Also isn't the clutch linkage totally different then?
Old Apr 28, 2017 | 10:11 PM
brian1080's Avatar
brian1080
Bell housings from 351/400 fit a 460
Old Apr 29, 2017 | 03:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All 1968/82 460's came with the C6.
1983 was the first year the 460 was available w/a M/T & 4WD
All: 1983 F250/350 6.9L Diesel & 460; 1984/96 F150/350 & Bronco; 1997 F250 H/D & F350 have a hydraulic clutch.
Old Apr 29, 2017 | 07:59 PM
Blue and White's Avatar
Blue and White
It would help to know what your current transmission is. If it is a NP435 it has a removable bell housing and is tough enough for the 460. You could potentially re-use the transmission with new bellhousing.
https://www.novak-adapt.com/knowledg.../manual/np435/
Old Apr 29, 2017 | 09:30 PM
Molson003's Avatar
Molson003
i have what what I believe to be a 73 Lincoln 460 I bought back in the day and rebuilt it now I am trying to put it in a 78 f250 4x4that had a 306 in it that went bad and I don't have any trans parts or anything I plan to use it for hauling and some fun. I have never done a swap like this and I feel lost.
You guys have been clearing a lot up for me but I'm still not shure which trans will best suit me yet or where to find one.
Thise site is awsome!
Old Apr 30, 2017 | 07:30 AM
Blue and White
OK... no transmission now. The NP235 is a good choice. It is tough and can handle the power/torque of the 460, was used a lot on Ford PU's and is readily available from yards and several rebuilders. It can be retro-fitted with mostly factory hardware (bell housing linkage ect.).
On the NP435, 1'st is a creeper gear for crossing rough ground slowly or to help get moving when very heavy. In day to day driving, you start in 2'nd and it is functionally a 3 speed. Top gear is 1:1.
The five speed transmissions mentioned have overdrive which is nice but they are harder to find. Some folks have adapted later Dodge 5 speeds. The Tremtec TKO new 5 speed is nice also and expensive.
The NP435 would be straight forward and cost effective with minimum engineering/fabrication. The 5 speed options are more involved and can get quite costly though having overdrive is really nice.
Old Apr 30, 2017 | 07:43 AM
SlikWillie's Avatar
SlikWillie
As far as the clutch linkage goes:
NP435 & T18 have mechanical linkages
ZF5 uses a hydraulic clutch
Is the ZF5 worth the mods to your truck? That depends on the truck usage and who you talk too.
Old May 7, 2017 | 07:13 AM
Molson003's Avatar
Molson003
Transmission?
i have the transmision off the six cylinder that looks like the np435 I think how can a person tell if there is no tag on it. Just a case number. And if it is right do I need to modify it
Old May 7, 2017 | 06:22 PM
Blue and White
See a transmission identification guide link. That should help make sure you know what you have.
If it is a NP235, the major change would be a new bellhousing to mate it with the 460. The bellhousing is bolt on and the 460 shares the same engine bolt pattern as the 351M and 400 so a correct housing should not be too hard to find.
Manual Transmission Identification Guide - FORDification.com
Gered.Corbin
Feb 18, 2019 10:52 AM
rednekk1
19
Mar 25, 2011 01:25 PM
78 PEB
Jan 9, 2011 03:33 PM
mike83f250
Oct 11, 2009 05:24 PM
Pickupmanx2
Sep 26, 2007 11:07 AM
