New gas tank with inboard fuel pump
Old Feb 16, 2017 | 11:25 AM
tip49's Avatar
tip49
Have ordered a new gas tank and EFI fuel pump kit to replace the rail mounted pump I have now. I have never liked the performance and noise of the rail mounted pump. It seemd to over heat easily and really whine about it.
Will be removing the F32A Mustang style between gas tank, weather permitting, and see if this solves my issues. Will use new, same tank model, but modified to accept the fuel pump.
Old Feb 16, 2017 | 12:10 PM
schoo's Avatar
schoo
any pic of FI you have now and maybe a pic of before/after of tank and filler you already know how we are about pic's
Old Feb 16, 2017 | 06:27 PM
tip49's Avatar
tip49
Tank pictures
I ordered the parts today for Tanks Inc kit.
I am using the F32A aftermarket 1973 Mustang tank currently, have ordered the same tank as I didn't want to cut and weld on a used tank. The fuel pump is a kit that will fit into the tank after opening a 4" hole on top of tank.
I think I may have to fiddle with the sender as it may not be compatible with the gauges I have,
I'll take pictures as I go, but am currently troubleshooting the voltage regulator and EEC relay problems that came up early December.
Old Feb 16, 2017 | 08:38 PM
Squirlyjim's Avatar
Squirlyjim
On your old set up were did you have the pump mounted and was the filter befor or after the pump the reason I'm asking is you shouldn't have the problems your talking about if the pump is as close to the tank as possible and the filter is after the pump with fuel being pushed through not pulled.
Old Feb 16, 2017 | 09:05 PM
tip49's Avatar
tip49
Fuel pump location
My fuel pump now is located on the passenger frame rail, behind the cab, fuel filter is after that.
The in-tank fuel pump is going to be more efficient, and quieter. (in theory)
Old Feb 16, 2017 | 10:44 PM
Squirlyjim's Avatar
Squirlyjim
Before you go through all that work you should try putting a lift pump in the tank. There high volume low pressure pumps that assist high pressure pumps that are mounted up closer to the engine. I had the same problems noisy and running very hot till I moved the pump back next to the tank. So I didn't have to use a lift pump never had another problem and much quiter. Just giving my thoughts.
Old Feb 18, 2017 | 06:28 AM
reg1952's Avatar
reg1952
I used an inline pump off a 90's E150. Only time I hear it is on start up.
Old Feb 18, 2017 | 09:38 AM
schoo's Avatar
schoo
I used a the same from a 89 e250 it's on the frame rail under driver seat
Can only hear it on start up before starter is in gauged, it is incasted in rubber
Old Feb 18, 2017 | 11:06 AM
tip49's Avatar
tip49
Sure..now you tell me
I may post video with pump running. It has never performed well, probably due to starving for fuel or some other design issue. I have tried everything from running it with fuel cap off, to actually replacing it.
I hope the new install makes it all go away, it is definitely annoying. Now I can take the time to vent the tank properly and make sure the fuel is regulated to the fuel rail.
Old Feb 18, 2017 | 11:43 AM
Squirlyjim's Avatar
Squirlyjim
Well it sound like your really set on that new pump but I'm sure you would love to know WHY hopefully you'll see something when you remove the old system. One more thing I forgot to mention is your return line its best of it returns under the fuel level so that it doesn't create a bunch of air bubbles in the tank all the time. Good luck and let us know how it turns out.
Old Feb 18, 2017 | 03:05 PM
schoo's Avatar
schoo
Is your EFI oem or after market
Old Feb 18, 2017 | 03:59 PM
tip49's Avatar
tip49
Stock EFI from 1990 Ford CV donor
Here is what I'm up against. The fuel pump is after market mounted on frame rail behind cab. It has got to go.
https://www.facebook.com/tom.pollock.9638/videos/10208284331414880/
Edit: As my video was not getting any hits, I removed the link.
Old Feb 18, 2017 | 08:28 PM
tip49's Avatar
tip49
Video post
Sorry for the lengthy video, I intended to post the edited version but you get an idea of the fuel pump noise.
This really is the only large project left to do on the truck, the rest will be mostly cosmetic on the interior. Well that and the voltage surging.
Old Mar 15, 2017 | 10:52 PM
tip49's Avatar
tip49
Waiting on parts
Been waiting for a month on delivery of replacement tank and fuel pump; follow up today seems I am in a "back order" condition. A shame as the weather has been perfect for getting the job done.
Worked on re-doing my tailgate latches. At least made progress on those.
Tom
jerry_s
Feb 18, 2015 11:07 PM
meganjoe
Oct 29, 2011 05:57 AM
octaneforce
21
Sep 11, 2011 08:01 AM
99f350sd
Jun 15, 2003 10:54 PM
rusty 58
Dec 8, 2000 10:35 PM
