PLUMBING A VINTAGE AIR UNIT WITH SS HARDLINE
Old Feb 15, 2017 | 08:37 PM
jniolon's Avatar
jniolon
old and in the way
it's time to plumb up the a/c thru the engine room.
I want to (if possible) use stainless steel hardline from the bulkhead fitting at the firewall to heater connections and the compressor and dryer... but having a very difficult time finding fittings I need...
Anyone ever plumbed one up this way or know someone that has... I seriously need some advise/input/direction. I've seen pictures so I know it's doable..but sadly none of them have part numbers labeled on them...
I need a rod shop in Bham (or close) that doesn't only know about Asian imports
thanks
john
Old Feb 15, 2017 | 08:41 PM
raytasch's Avatar
raytasch
Believe Nothing
I would be hesitant to run hard lines to the compressor. I would think there would be a need for flex to accommodate engine movement. Vintage Air has a pretty complete parts list on their web site. I found the folks there helpful with fitting selection. My install was nothing fancy.
Old Feb 15, 2017 | 11:10 PM
Rusted56's Avatar
Rusted56
My kit came with hard lines for inside the cab, but I found it pretty tight in there, and had the A/C shop make flexible rubber ones. Cost a bit more, but worked well.
Old Feb 15, 2017 | 11:13 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I thought Vintage Air had aluminum and stainless lines at various lengths you could bend as needed.
Old Feb 16, 2017 | 01:21 PM
das54's Avatar
das54
Vintage Air has U-Bend-Em hard lines, #6, #8, #10 in 8 lengths from 1 ft to 6 ft. I think Summit Racing stocks all the sizes. I was very pleased with the custom hoses I got from ColdHose in FL.
Old Feb 16, 2017 | 05:07 PM
jniolon's Avatar
jniolon
old and in the way
they have the kits but they are hi $$$ the stainless kit for the A/C ONLY is 470.00
then you still have to do the heater lines...
I can get the tubing for free which saves a good bit... one problem is mixing alum fittings with ss and vice versa... I found stainless fittings for barrier hose and I'm wondering if I can cut off the crimp fitting and just weld the -10 fitting and tube to the ss tube I have... gonna call some folks tomorrow and see....
and Ray... SS compressor line will have a short barrier hose end to deal with vibration..thanks for thinking of that
john
jniolon
21
Jan 2, 2019 11:31 AM
jniolon
Feb 15, 2017 08:34 PM
mechmagcn
27
Feb 17, 2013 06:02 PM
ford2go
Garage & Workshop
13
Jul 27, 2009 01:33 PM
tcool
Mar 27, 2005 08:52 PM
