battery selection?
Old Feb 13, 2017 | 02:00 PM
GoldCo's Avatar
GoldCo
Question battery selection?
though still a bit off, i'm looking forward now to getting everything together in order to actually fire up the motor for the first time... which means i'll need a battery.
what considerations apply? since i don't plan to mount in the engine compartment, fitment really isn't an issue. would like to run an optima (had good luck with one "back in the day" of rockcrawling w/ the jeep).
so presumably just cranking output and post mount preference?
thoughts on red top vs yellow top?
no power windows or locks planned, though hopefully a decent sound system at some point down the road. 351W, EFI. will spring for a new alternator, too (so anything to keep in mind in that regard, too?).
thanks in advance.
Old Feb 13, 2017 | 05:30 PM
chad77's Avatar
chad77
thanks in advance.
I used a red top. Good strong battery.
Old Feb 13, 2017 | 09:04 PM
Moe Craig's Avatar
Moe Craig
I'm also running an Optima Red Top battery... I want to add a second, for a dual battery system. I also want to move them behind the seats, after I move the fuel tank to under the bed.
Old Feb 13, 2017 | 09:34 PM
burnettd01's Avatar
burnettd01
Battery lication
I am running a sealed battery (not optma) and I have decided to mount it off of the frame inside the rear of the passenger front fender.
Bought a sealed battery box (a little big) but I think it will work. I am still in the process of building the battery tray. I will keep you all updated.
Thanks
Dan
Old Feb 15, 2017 | 01:01 PM
petemcl's Avatar
petemcl
Yes, Optima is expensive but if you have a project truck that may sit for a while the the Yellow Top is better as it is designed to hold a charge even while sitting and have more power available between charges.
Old Feb 15, 2017 | 04:18 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I've been running a Red Top for about 7 years. the Yellow Tops do have more of a deep cycle desighn, but My Red Top still starts first time every time even after sitting a few weeks. The only time I ever had any failure was due to a short in the truck a few years back that drained it, a quick jump and it has never had any problem since. I would definitely buy another one.
nagetech
Mar 10, 2015 01:48 PM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
Medic 66
Jun 25, 2005 07:31 PM
wcmo sae
Jul 10, 2004 08:57 PM
Ken2600
15
Oct 13, 2002 09:15 PM
