Sponsored by: Real Truck
2000ford transmission just stop no noise nothing
Old Jan 23, 2017 | 02:28 PM
Reno Moats's Avatar
Reno Moats
Was driving my 2000 Ford F-350 stopped transmission would not move no more there was no noises no nothing just stopped pulling no gears nothing only Park works (help)
Old Jan 23, 2017 | 02:32 PM
Kdr358's Avatar
Kdr358
What engine?
2wd or 4x4?
when was the last service/condition of the fluid?
how many miles?
Old Jan 23, 2017 | 02:50 PM
Reno Moats's Avatar
Reno Moats
Originally Posted by Kdr358
What engine?
2wd or 4x4?
how many miles?
4x4 motor 7.3 135000 change filters and fluid two years ago
Old Jan 23, 2017 | 02:57 PM
redford's Avatar
redford
FTE Leadership Emeritus
Does it have fluid in it?
Is anything on the instrument panel or gear selector blinking at you?
Old Jan 23, 2017 | 03:03 PM
Reno Moats's Avatar
Reno Moats
What engine?
2wd or 4x4?
how many miles?
Yes fluid is full looks like new no lights on the dashboard it was like someone flip a switch I even tried to put it 4x4 no leaks no where
Old Jan 23, 2017 | 08:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Something mechanical broke inside the transmission. It's done. Sorry.
Old Jan 23, 2017 | 08:55 PM
Reno Moats's Avatar
Reno Moats
One last? Could it be the solenoid on the outside of the transmission because it got wet from fuel leak
Old Jan 23, 2017 | 09:05 PM
Mark Kovalsky
There is no solenoid outside of the transmission. There is a sensor, and it cannot cause this. The only way this can happen is if something mechanical breaks inside the transmission.
Old Jan 24, 2017 | 12:35 PM
Mike1's Avatar
Mike1
Could the rear end have gone out instead? Did you look at drive shaft to see if it's spinning while in gear? Did you try locking into 4x4 to see if it moves?
Just thoughts going through my head, I'd hate to see it's the trans.
Old Jan 24, 2017 | 01:03 PM
redford's Avatar
redford
No.
The OP stated that PARK works. It would not if the rear differential was munched.
Old Jan 24, 2017 | 01:15 PM
Mark Kovalsky
Or if the transfer case failed.
Bayou_Flyer
Mar 1, 2008 11:12 AM
96fordgirl
Oct 17, 2007 12:51 PM
jclarke2899
Mar 24, 2004 03:01 PM
landolakes
Jan 10, 2004 09:33 PM
