Speedometer Calibration For Tire Size
Old Nov 17, 2016 | 12:04 AM
TexasGuy001's Avatar
TexasGuy001
Question Speedometer Calibration For Tire Size
I recalibrated the PSOM for 31 10.50 15 tires using the code 9.14. Since doing that, the speedometer reads nearly 5 mph higher than it should at 70 mph. I'm wondering if I should reprogram it for a 30 9.50 15 tire using code 9.52 or try something in between those two. I have recalibrated the PSOM for this tire size before with the same setup on my last truck and the speedometer was accurate within 1-2 mph at 70.
Old Nov 17, 2016 | 12:25 AM
The_Drew's Avatar
The_Drew
I would suggest actually measuring the tire before recalibrating. Actual tire sizes vary between manufacturers even within the same "measurements"
Old Nov 17, 2016 | 04:21 PM
jas88's Avatar
jas88
I always use percentage to tell me how much. You need to reduce speed by 7%. How much was it off before you did the calibration?
Old Nov 18, 2016 | 12:36 AM
TexasGuy001
It seemed to read about 5 mph low, but I never checked it with GPS before recalibrating it.
Old Nov 18, 2016 | 09:21 AM
jas88's Avatar
jas88
I've forgotten now, it's been so long, but aren't you only allowed a certain number of times you can reset the tire rotation value?
Old Nov 18, 2016 | 03:49 PM
rla2005's Avatar
rla2005
I believe that number is 6
Old Nov 18, 2016 | 03:53 PM
TexasGuy001
Yeah, it is limited to 6 so there are 5 remaining. I have no idea why Ford designed it that way.
Old Nov 18, 2016 | 04:36 PM
BLK79's Avatar
BLK79
I think the older PSOM's are only allowed 3 changes. Mine is a 92, and does NOT show how many calibration changes remaining, which I have read means it was limited to 3.
Old Nov 18, 2016 | 05:40 PM
Eddiec1564's Avatar
Eddiec1564
To keep odometer fraud from occurring is main reason.
There is a way to reset that back to 6 just need to be able to copy and write the EEPROM of the PSOM.......and no anything over 6 will crash it....
LostKnyt
2009 - 2014 F150
Jun 28, 2014 10:19 PM
F150vettehauler
2004 - 2008 F150
May 5, 2014 01:58 PM
boulderbronco
6.4L Power Stroke Diesel
Jul 9, 2013 09:28 PM
Scorpion
Nov 16, 2006 01:49 PM
fordtruck88
Aug 16, 2005 07:24 PM
