1965 E brake
Old Oct 30, 2016 | 06:45 PM
Jesses1999f250's Avatar
Jesses1999f250
1965 E brake
Hey guys, I have a question about the E brake for my 1965 f100 longbed. I purchased E brake cables that are for my specific year and bed length, but the cables won't reach the other piece? They're about 12 inches or so too short. Is there a piece that is suppose to go in between these that I'm missing?
i posted a picture below of another truck because I already removed my cables, but as you can see on his, the cables are too short aswell? It really looks like there's suppose to be another piece.
thanks!
Old Oct 30, 2016 | 07:10 PM
daveengelson's Avatar
daveengelson
Link may find helpful; thorough description of the components in the E-Brake assembly with diagram. I am unable to determine from pic if the equalizer bar and E-Brake lever are attached to the E-Brake cable; refer to ND diag., if so, then 12" is quite a distance to make up. Once rain lets up I can crawl under the 65 and measure.
https://www.ford-trucks.com/forums/1...-assembly.html
Old Oct 30, 2016 | 07:23 PM
Jesses1999f250
heres a picture of my truck. I don't have the cables in, but when they were in they were the same length as the original picture I posted. So as you can tell, there a bit of distance from the cables to that attachment.
Old Oct 30, 2016 | 07:49 PM
aj64f100390-292's Avatar
aj64f100390-292
interesting that they changed the e brake compoanets in 65 my 64's cable attachment piece is at least 4" longer and the brake handle cable z bar "thing" is curved almost a sorta half moon shape .., wonder why they made this change
...well i say that the 64 cross meember is further up than the 65 and up...if im thinkig right thats where the attactment would go..
Old Oct 30, 2016 | 07:56 PM
Jesses1999f250
Alright, check this out. Just found this picture online, as you can see they have an attachment that fills in the gap that I currently have. Does anyone know what that would be called so I can buy one?
Old Oct 31, 2016 | 08:31 AM
aj64f100390-292
im not trying to distract from your issue or hijack ur thread but...what fuel tank did you use?, is that setup going to come out the side of the bed or or the bed floor?
Old Oct 31, 2016 | 08:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jesses1999f250
Hey guys, I have a question about the E brake for my 1965 F100 longbed.
Are there extensions that are supposed to go in between these that I'm missing?
2) C5TZ-2A793-A .. Extension-Parking Brake Cable - 14" long / Obsolete
1965/66 F100 with 129" wheelbase (8' bed).
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 220-686-5101.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 7 = 800-543-4959.
See 2A793 in pic:
Old Oct 31, 2016 | 09:54 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Interesting that it only applies to F100 with the 129" WB.
I bet he would also be interested in the
C6TZ-2A790-A - Connector
Looks like plenty of those available NOS as well.
Old Oct 31, 2016 | 10:10 AM
NumberDummy
I bet he would also be interested in the C6TZ-2A790-A - Connector
I looked up this connector along with the extensions, but...
OP has a 1965 F100, this connector is only listed for 1966 F100 129" wheelbase; 1967/72 F100 131" wheelbase & F350 158.8" wheelbase; 1969/74 E100/200 123.5" wheelbase.
Old Oct 31, 2016 | 10:18 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Bill, I see that now that I look closer. I wonder how the cables connect to one another in 1965?
So there was both a 128.8" (129") and a 131" WB in 1967? It shows both under that part number. Seems odd, but I've never even glanced at a 1967 so know nothing about them.
Old Oct 31, 2016 | 10:21 AM
TA455HO's Avatar
TA455HO
Lead Gopher
You don't suppose that 66/67 is a typo and it should really read 65/66 - do you think that is possible? I've documented a TON of other Errata in the MPC so I wonder about this entry, too.
Old Oct 31, 2016 | 11:11 AM
NumberDummy
C6TZ part number prefix reflects 1966
O-S-I catalog doesn't show that C6TZ-2A790-A replaced a previous number.
But, if the OP wants 2 of these...just to be sure...you or I can list some of the sources.
Old Oct 31, 2016 | 11:30 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, if your O-S-I catalog doesn't show a previous number then it would seem to be as you say.
Old Oct 31, 2016 | 11:45 AM
Jesses1999f250
See 2A793 in pic:
Just ordered it. Thank you very much!
tinman52
25
Jun 15, 2021 08:43 AM
Troy_Lee
Feb 26, 2018 09:01 PM
rews2
13
Mar 11, 2016 01:02 AM
rookieford
Feb 14, 2016 03:31 PM
abyars111
Aug 12, 2015 01:15 PM
