Parking brake attachment
Old Feb 14, 2016 | 02:25 PM
rookieford's Avatar
rookieford
Does anyone have a picture, or can explain how to attach this clip for the cable to stay on the lever? Am I missing anything?
Old Feb 14, 2016 | 02:38 PM
Steven@nd's Avatar
Steven@nd
That holds the lever to the brake shoe... the lever has a pin that goes through the shoe and that clip goes in the groove and gets bent together so it can't come off.
Your adjusting wheel and tin look wrong to me... this is how mine is put together:
Old Feb 14, 2016 | 02:41 PM
460me's Avatar
460me
Need to look at a diagram. The cable or arm needs to go the other way,the hook part of the arm is what holds the cable.The horse shoe looking thing is a clip/holder,slid it in and pinch the legs together.It is not for the cable.
pic
http://ww2.justanswer.com/uploads/AS...ke_diagram.jpg
Old Feb 14, 2016 | 02:43 PM
Steven@nd's Avatar
Steven@nd
Here is a pic showing that clip, you can see it at the top:
Old Feb 14, 2016 | 02:48 PM
Steven@nd's Avatar
Steven@nd
Here is a pic of a 9 inch drum brake set up without the axle in the way...
Old Feb 14, 2016 | 02:51 PM
rookieford's Avatar
rookieford
We are working on a 3/4 ton truck (1976 F250 4WD), and the brakes are slightly different from 1/2 ton trucks. Based on the diagram I attached below, we wouldn't need that horseshoe clip then? The adjuster looks put together correctly also based on the diagram attached. Any word on how to attach cable to lever? Thanks for the replies.
Old Feb 14, 2016 | 02:57 PM
Steven@nd's Avatar
Steven@nd
In that case it looks like you are missing the spring that goes over the park bake cable - that spring is what holds it on the lever.
Old Feb 14, 2016 | 03:18 PM
rookieford's Avatar
rookieford
Ok, we were wondering about the springs. We got new parking brake cables from AutoZone, and they have a spring on the end I thought went under the truck. We will try to flip the cables and see what happens. Thank you.
Old Feb 14, 2016 | 03:31 PM
rookieford's Avatar
rookieford
Yes, I had put the cables in backwards. We are in the process of fixing them. Thanks everyone for your input.
50mercman
Mar 16, 2018 09:57 AM
Troy_Lee
Feb 26, 2018 09:01 PM
glen_melton
Mar 13, 2015 01:05 PM
BigRyanKP
Jan 27, 2007 03:57 PM
daring
Dec 5, 2003 12:10 AM
