Which Coil do I need with my Electronic Ignition?
Old Sep 6, 2016 | 01:40 PM
wavetrain75's Avatar
wavetrain75
1949 F-1 flathead V8
*ETA: 12 volt system*
What coil resistance do I need?
I ordered a Pertronix ignition from Mac's a couple years ago. It was listed to work in my year flathead V8. I managed to lose the instructions and other relevant information, and now I don't know what coil to run with it.
It dropped in easily to the stock distributer and gives me a nice big blue spark but I have no idea if I'm running the right resistance and thought maybe I should quit before I cook something. I will not run a ballast resister, I just want to get the right coil and be done with it.
Old Sep 6, 2016 | 02:54 PM
49George's Avatar
49George
I installed the PerTronix ignition in my 49F1 last year. PerTronix tech support advised me to install the PerTronix 40011 Flame-Thrower 40,000 volt 1.5 ohm coil.
Old Sep 6, 2016 | 03:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The instructions are here but don't give any real guidance:
http://static.speedwaymotors.com/pdf/447-1144.pdf
I run an MSD electronic distributor and I had to pry it out of them that they recommend a coil with 0.7 to 1.4 ohms. They recommend their Flamethrower coil, which has a 0.7 ohm resistance. Not the same as a Pertronix, but similar. Flatheads just don't need (or benefit from) 40,000 volts!
Old Sep 6, 2016 | 03:51 PM
Brian~50F3's Avatar
Brian~50F3
I also used coil 40011 on my positive ground stock 226, along with igniter kit 1266P6.
Pertronix has their instructions on the website, here's a P6 (6V Positive gnd) example http://pertronix.com/docs/instructio...ts/1244AP6.pdf with coil reccomendations at the end.
Old Sep 6, 2016 | 05:53 PM
wavetrain75
My fault, this is a stock engine Except for being 12 volt. Does that change anything?
Old Sep 6, 2016 | 08:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I doubt it. Personally I'd aim for the high end of the resistances they list. At 12v, a 0.6 ohm coil could draw 20 amps! I don't know how they get away with 20 gauge wires for that. At 1.4 ohms, it drops below 10 amps. I just went to NAPA and bought a generic coil that was listed at (IIRC) 1.4 ohms.
Old Sep 8, 2016 | 02:11 PM
wavetrain75
I asked the Local Auto Parts Retailer for a 12 volt coil in the 1.3-1.5 ohm range and they sent be home with general purpose coil.
Checked it with the ohm meter - 2.1 ohms. Haven't installed it yet, can most likely return it. Or should I throw it in and give it a try.
ETA: Cold coils can read a little higher resistance?
Old Sep 8, 2016 | 02:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If it doesn't work, it won't be returnable, and "could" damage the Pertronix
Take your ohmmeter with you to the store
Old Sep 8, 2016 | 02:35 PM
wavetrain75
That all sounds reasonable. I know the guys at the store and coil is still NIB so I'm sure they'll exchange it.
I'm researching coils trying to find out the formula for ohms vs application so I can at least have a little understanding what I'm doing.
Old Sep 8, 2016 | 03:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
They aren't the cheapest, but the NAPA coils I've found are:
IC12SB 1.5 ohm
IC10, 1.2 ohm
Old Sep 9, 2016 | 12:54 PM
petemcl's Avatar
petemcl
I did the same thing. It was a great improvement.
captntim
May 3, 2024 12:36 PM
Planejet42
Jun 12, 2017 06:17 AM
peka
34
May 20, 2015 01:20 PM
78 & 87 Super Cab
Dec 23, 2014 06:32 PM
abe
Jan 1, 2013 04:51 PM
